Question about Brother P-Touch PT-85 Label Tape OEM 0.47" Black Print on Clear - Label-Tape-P-Touch-PT-85
Brother p-touch 85 label maker will not print
Label maker will not print
  • 5 Answers
SOURCE: brother Model Pt-65
There are two vertical fonts - small and normal. To put the labeler into vertical mode, hold down the [Code] key and tap the [J] key.
When it asks " 1-9 ", let go of the [Code] key.
Press the [8] key if you want small vertical type, OR the [9] key if you want normal size vertical type. Then you have to hit the [ <--' ] enter key.
Now you are stuck in Vertical mode ! :-O
To get back to normal, hold down the [Code] key and tap the [J] key, Let go of the [Code] key.
Then tap the [3] key and the enter [<--'] key. You are back to horizontal labelling.
:-) phew!
Posted on Jul 28, 2008
loumsc
  • 114 Answers
SOURCE: brother PT-85
Make sure you have fresh batteries, It sounds like the batteries are low,
Lou
Posted on Aug 10, 2008
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Posted on Dec 29, 2008
  • 7 Answers
SOURCE: Ink will not print
www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
Posted on Apr 09, 2009
paul7of9
  • 1189 Answers
SOURCE: too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Posted on Jan 04, 2010
P-touch extra label maker is printing upside down and back to front
You have turned on the "Mirror print" option.
Here is a link to the manual. Go into the print functions and look up the Mirror Print option, that will show you how to turn it off:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
May 08, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
I have an "old" p
When labels print i get back ground i do not want
Mar 04, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
Too much tape
Jan 04, 2010 | Brother P-Touch 1180 Label Printer
Brother P-Touch 85 only prints one vertical line,then shuts off
Normal 0 Driver could be corrupt.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Brother P-Touch 85 Thermal Label Printer
Ptouch weak printing
You need to take a q-tip dipped in alcohol and clean the printhead. Let me know if this helps.
Lou
Sep 09, 2008 | Brother P-Touch 1180 Label Printer
Brother PT-85
Lou
Aug 10, 2008 | Brother P-Touch 1180 Label Printer
Labels are not printing correctly
Brother P-Touch tape label maker doesn't print right.
I believe it's a faulty tape. I put in a new tape, reset the machine and it's now printing fine. It wasn't the reseting - I tried that before.
Mar 11, 2008 | Brother P-Touch 2200 Thermal Printer
Brother P-Touch PT-85 Label Tape OEM 0.47" Black Print on Clear - Label-Tape-P-Touch-PT-85 Logo
158 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
