Question about JVC GR-D270 Mini DV Digital Camcorder
Camcorder is saying unit is in safe mode eject and reinsert tape. I have ejected the tape and removed the battery but the colde wont go away
SOURCE:
magic seadog
  • 38 Answers
SOURCE: safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Posted on Aug 12, 2007
SOURCE: unit in safeguard mode
I have a DVL520U,
I may be lucky from what I have read, but this is what I did.  I took out the tape, released the tension on it by pressing the small tab between the wheels (I observed a slight wheel movement).  I took the eraser end of a pencil, and while holding the tab, rotated the spindles of the tape 10-15 rotations back and forth (this from the vcr days and tracking problems).  I put the tape back in and the problem went away.  I thought of this after reading post after post and then finding the definitions of the error codes on a french website.  Codes 4-6 seemed to be with the mechanical aspects of the drive, codes 1-3 with the sensors etc.  All in all it was a guess on my part.  If any of this works for you, pass it along.
Posted on Oct 12, 2007
  • 12 Answers
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Posted on Jul 04, 2008
welcomejee
  • 10594 Answers
Please remove and reattach battery and hope this will resolve 03 error issue in your JVC camera.
Posted on Dec 06, 2008
SOURCE: unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Posted on Dec 30, 2008
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
The cassette holder wont come up aoutomatically
what you have to do is ejecting the tape, and as soon as it starts to eject , close the door immediately, then safeguard mode should be gone, and you will be able to eject normally.
Mar 04, 2008 | JVC GR-D290 Mini DV Digital Camcorder
MY CAMERA SHOW E03 ;unit in safeguard mode ;EJECT AND REINSERT TAPE WHT SHOULD I DO............
JVCGR-D270.Digital Camcorder. When we put the tape in the cam it chews the tape whiles loading and says that it's in 03 safe guard mode. Please help.
Jan 24, 2011 | JVC GR-D73AG Mini DV Digital Camcorder
Unit in safe guard mode why , it reads on screen jvc gr-d225e can you help me.also says Eo4 eject and reinsert tape but the tape well not inject when open. help.
I JUNNKED THE CAMCORDER AND GOT A GERMANY CAMERA ; ITS SAD
THAT YOU DID HELP ME WITH THIS LITTLE PROBLEM; NOT EVERTHING IS BASE ON MONEY; I ASK FOR HELP AND YOU ONLY
WONTED MONEY. sad sad
Sep 10, 2009 | Video Cameras
Unit stuck in safeguard mode
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Jvc digital video camera mini dv gr-d244u
I have had the same problem...usually had success by taking off the battery, putting it back on, turning the power off and on, etc.  It has always gone back in eventually.  I also tried re-charging the battery and replacing.  Could this be an old battery problem?  Mine is 4.5 years old.
Jan 06, 2008 | Panasonic Palmcorder PV-GS9 Mini DV...
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
Unit in safeguard mode
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-D270 Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
