Question about Bose Audio Players & Recorders
How i can reset rc48s2
I can't open instalation
I had Bose lifestyle V35, V20 try to link together. Bose link AL8 transmitter will not connect to receiver. both led is light solid green. Please help.
The commands for the Bose link system are actually going through the remote control system. In order to use the system you need not only a set of AL8 sender and receiver, but also a special remote control model RC48S2-40 these model numbers are slightly different for the US and for Europe. In addition you will need to activate the BoseLink connection through the system settings menu and you will need to tell the remote to which system it needs to talk. When you have done all that, there should not be any problem to "connect" the two systems. If this does not work, you may need some specialized help from a Bose specialist who understands this multi room set-up.
Nov 09, 2014 | Bose link AL8 wireless home-wide audio...
My RC48S2-27 won't turn on? Any thoughts?
Could be a battery problem or possiby total failure of the remote.
Jul 02, 2014 | Bose Remote Control RC48S2-27 p/n:RC48S227
Bose rc48s2 remote not receiving signal
make sure the lens on the remote and the one on the Bose are clean. If that does not work, replace the remote. Buy a used on on ebay.
Dec 21, 2013 | Bose RC-48S Remote
Hello I have a bose surround sound system in my house, both inside and out. It appears that only the inside portion of the surround system works and the remote for the outside portion the RC48S2-27 model...
I think we're discussing the Personal Music Center II.
I had to back into the product from the remote model number. Can we assume you also have one of the compatible LS systems (18 or 28 Series II or the 38 or 48) ?
You can go to Bose.com and search for it or register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Bose-Personal-Music-Center-II-Universal-Remotes-manual/id/526dj583/t/2/
The first item in Troubleshooting (page 28) might explain what's happening.
Jun 18, 2011 | Bose PERSONAL music center II System
Internet explorer finds a problem with the web ppage and wont open the game the rooms are there but wont let me into them i have updated my flash player and adobe reader etc
Try This:
How to Reset Internet Explorer settings
By resetting Internet Explorer settings, you return it to the state it was in when it was first installed on your computer. This is useful for troubleshooting problems that might be caused by settings that were changed after installation. When you restore Internet Explorer's default settings, some webpages that rely on previously stored cookies, form data, passwords, or previously installed browser add-ons might not work correctly. Resetting Internet Explorer to its default settings does not delete your favourites, feeds, and a few other personalized settings. See the table below for a complete list of all settings and information about whether they are reset or maintained.
Resetting Internet Explorer's settings is not reversible. After a reset, all previous settings are lost and cannot be recovered. Rather than resetting everything, you might want to reset specific settings or delete your webpage history.
To reset Internet Explorer settings use the following procedure
You need to make sure you have Closed any Internet Explorer or Windows Explorer windows that are currently open.
Open Internet Explorer and Click the Tools button, and then click Internet Options.
1.png Click the Advanced tab, and then click Reset.
2.png In the Reset Internet Explorer Settings dialog box, click Reset.
3.png When Internet Explorer finishes restoring the settings, click Close, and then click OK.Close Internet Explorer.
Your changes will take effect the next time you open Internet Explorer.
Jun 02, 2011 | Facebook Apps
Hi, i am using dell insprion 1525 laptop. i am faceing problem in netwoek drivers . i am not able to install network drivers and at lan card palce i am getting red light please help me .. praveen kumar
Boot the computer in Safe Mode with Networking and see if it connects that way. If not, try this fix.
TCP/IP stack repair options for use with Windows XP with SP2/SP3.
Start, Run, CMD to open a command prompt:
In the command prompt window that opens, type type the following commands:
Note: Type only the text in bold for the following commands.
Reset TCP/IP stack to installation defaults, type: netsh int ip reset reset.log
Reset WINSOCK entries to installation defaults, type: netsh winsock reset catalog
Reboot the machine.
Download Network driver :- R161378.EXE on support.dell.com
Jan 16, 2010 | Dell Computers & Internet
Gettng my RC28T1 40 to connect with my LS28 system
i have a bose control, model RC48S2-40 and start the system but does not have control for volumen and change only from fm to cd dvd, is conected to other system bose from other rooms
Apr 10, 2009 | Bose RC-18S Remote Control
Linksys can't find ip address
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
Aug 13, 2008 | Linksys Wireless-G WRT54G Router
OPENING N91 THEMES
suggest me what are the external softwares supported for NOKIA N91 4Gb
Jun 19, 2008 | Nokia N91 Cellular Phone
Unable to open links
go to mozila.com and install firefox browser. If you already have firefox then un-install it and re-install it. If you have Internet explorer then update it from microsoft.com
Oct 03, 2007 | Fujitsu LifeBook E6560 Notebook
10 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
