Question about Radio Communications
Want to use astatic d104 mic for motorola maxtrac two way radio not a cb radio
The audio is to low its a motorola maxtrac radio.the keying circuit wors fine
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
With using a D-104 on a Maxtrac, you will probably need an audio amplifier.
Tom
Posted on Apr 27, 2014
eradiostore
  • 1654 Answers
SOURCE: Transmit button on the lapel mic will not key the radio
Two things which come to mind, one would be if the PTT on the remote mic is bad/defective, second would be you are plugging the audio device in with the radio turned on.
If your remote mic is failing, the PTT is a repairable item, as is the cord on most models.
Posted on Mar 30, 2009
SOURCE: mic wiring
Here is the wire diagram for the Galaxy:
1-SHIELD
2-MOD
3-TX
4-RX
I hope this helps you!
Posted on Apr 16, 2009
eradiostore
  • 1654 Answers
SOURCE: rick to maxtrac, is it the same a radius
Yes, if you have the 16 pin connector. (The 5-pin connector is not a compatible version.)
Posted on Feb 02, 2010
  • 2069 Answers
SOURCE: I have two motorola cp 185 radios. I was using
your unit is stuck in the external mic mode. when external mic is engaged, it automatically re-routes input to the external device. this situation can happen if such an external device has not been used on the unit in a long time. i would consider this a hardware issue rather than software. solution may be to open (dismantle the radio) and clean at the interface / jack for the external connection. this should sort it out.
regards
Posted on Jan 02, 2011
SOURCE: I have a pair of
Hi, actually I think you have answered your own query... in that the BT headsets, well NOT ALL, are NOT compatible with the Radios.
Usually if they do not "Just work" then they never will.
There are however ones that DO work, my advice is to contact Motorola and ask them for advise on exactly which ones will work.
http://phone.manualsonline.com/manuals/mfg/motorola/fr60_14.html
above is a link for a manual.
Posted on Mar 23, 2011
Astatic d104 wiring for Yaseu ham radio
( 9 Stand ) Astatic D104 to Yaesu FT 990
Pin 1 is White
Pin 2 is Red
Pin 7 is Shield/Blue combined
Aug 12, 2014 | Radio Communications
My astatic d104 mic squeals
like a pig it does . get it as far from the speaker as you can and if your radio has mic gain turn it down to about half . That should take care of it,but if it doesn't there is another way . You can change mics or open it up and solder a 4700 ohm 1/4 watt in line with the audio wire then solder a .001 waffer cap to one end of the resistor and another to the other end then solder them to the shield wire . ________________x________x________________ audio
l .001 l two .001 caps
l l
------------------------1---x resistor x _______________ shield
Apr 10, 2014 | Astatic Road Devil RD104E CB Radio
Microphone wiring
the rf power going out is geting inducted on the wires of the mic.try using some ferrites close to the coax on the pl259 connector and on the mic wire itself.
Mar 01, 2014 | Radio Communications
D-104 wiring to a cobra cb
Find your radio on this page and then look at the wiring diagrams
Oct 11, 2012 | Astatic D104 T - Ug8 Crystal Microphone...
Im trying to wire a astatic d104 m6b to a galaxy 949 mobile can you give a color code for what color wire goes were?i have black white red blue and a bare wire thank you.
This works for any mic.
dont worry about color codes. look at the switches.. there will be a common on both poles of the d104.. those need to be tied together to grnd. pin 1 on mic . the others d104 on n/c side is your rx. pin 4... the n/o one will be your tx pin 3 the other n/o will be audio and will have a wire from the mic element also on that pole of the switch. pin 2..
Sep 25, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
Radio Communications Logo
53 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
