Question about Jl Audio 300/4 Car Audio Amplifier
Does does the JL 300/4v2 have fuses?
I was in an rear end auto accident at which point my JL 300/4v2 amplifier quit working. I've checked all the power connections, and the remote lead and all are proper. Yet the amp does not power up. Could there be fuses internal to the amp that go jarred loose or blown?
SOURCE: bad amplifier need help!!!!
I had the same amp! It is the JL 300/4 and one of the chanels came in really fuzzy. It sounded as if the the wires were touching during my installation. I called JL and a JL authorized dealer it would have costed me 190 dollars total to get the amp fixed. Instead I opened up the amp to see if anything looked out of the ordinary. When you open the amp, see if the green fuse looking things are aligned. If they are not aligned then straighten them out. I think they had gotten out of place from being dropped becaue I baught my amp used. My amp works perfectly now!
Posted on Mar 06, 2008
  • 160 Answers
SOURCE: if my jl amp e1200 is on green, but no power is going to the sub
your audio wires from the head unit have been pinched or discontected or the head unit is not putting out a signal
Posted on Dec 01, 2008
  • 12 Answers
SOURCE: Jl 500/1 amplifier will not turn on
you may have burned the channel you were using..try taking the cover off the amp and checkin for burned spots or any wires that may be loose or touching within the amp.
Posted on Feb 26, 2009
  • 123 Answers
SOURCE: JL Audio 500/1 Amplifier "Thermal" light flashing
pooi
Posted on Jul 25, 2009
SOURCE: Amp comes on then shuts down JL 500/1
ive got a amp called xplod 450wots and its over heating but all the wires r all good just really really hot but also its got no vents wood that be the problem does anyone no..thanks jay
Posted on Jul 09, 2010
I have a jx jl 500/l, amp will not power down unless underhood fuse is removed
check your fuse on the battery and check the fuse on the amp or it might b loose connection of power line and the remote wire(the blue wire
Aug 27, 2013 | Jl Audio 500/1 Car Audio Amplifier
Amp quit producing output, power indicator is on
it can't be a fuse cause if it was then there would be no power you might have blown the speaker terminals. did you check to see if the sub was blown.
Jul 28, 2010 | Rockford Fosgate Car Audio & Video
Everythihng hooked up, smoke comes out
yes it is fixable , you will want to get in contact with a jl audio dealer or jl audio themselves
Jul 15, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl amp
If the battery is at or above 12v and the voltage at the amp (measured directly across the terminals of the amp) is 5v, that would require hundreds of amps of current which should easily blow the 80 amp fuse. If the fuse is defective, is would account for the voltage drop without excessive current draw.
Have you checked the ground connection between the amp and the vehicle's chassis ground point?
Aug 12, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Blown fuse
What size fuse are you using?
Have you checked the speaker to determine if it's damaged?
Do the speaker and amp produce clean sound up to the point where the fuse blows?
Aug 06, 2008 | Jl Audio 1000/1 Car Audio Amplifier
There are no fuses inside the amp.
Are any of the lights lighting up on the amp?
If so, which ones?
Jun 09, 2008 | Jl Audio 500/1 Car Audio Amplifier
Help
JL amps are somewhat sensitive to low voltage. Everything has to be perfect in the power supply feeding the amp. I'll assume that you have large enough wire. Check the owner's manual on the JL site. They likely recommend 4g or larger. You need to measure the voltage across the B+ and ground terminals of the amp. If it's dropping below ~11v when you turn the volume up, you need to determine why. Make the same measurements at the battery terminals. If there is significantly less voltage drop there when the volume is increased, check all of the points in the circuit where there could be a bad connection. Look for corrosion, over-heated connection on fuses or at the battery and make sure the fuse is in good physical condition. Some types tend to overheat and melt. If everything looks OK, begin measuring the voltage at each point where there is any sort of connector. If for example, you get a significant difference in the voltage on each side of the fuse, the fuse, the holder or the connections to the holder may be defective.
Oct 04, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 300/4 Car Audio Amplifier Logo
65 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
