Question about Funai ZV427FX4 DVD Recorder/VCR Combo
Playing vhs tapes in rapid speed
I just bought this unit yesterday. i played 2 hours of video fine. then it seems as thought the tape had a "funny spot" where the vcr hit a snag playing or something and now the unit will only play vhs tapes at rapid speed. i cannot get it to play at the normal speed.
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: VHS player stops after 5 seconds
Hi, Based on your post/description, sounds like a mechanical problem with the take-up spool. As this would involve mechanical diagnosis and repairs, your best bet may be to seek the services of a qualified professional. Should you want to venture do-it-yourself, you need to remove the top cover and expose the inner mechanism of the VHS tape player. Of course the usual safety precautions when working with electrically powered devices. Once the inside mechanism is exposed, you will notice that there are 2 spools where the tape would be sitting when fully loaded. The right side is the take-up spool responsible for winding the tape when played or fast-forwarded. When fast forwarding during stop-mode it is direct gear driven however during play and fast-play, the take-up spool is driven by a clutch sandwiched between the top portion and the bottom wider portion. You need to disassemble the take-up spool. It may be held in place by hard press, force-fit, lock or retaining clip. Normally there is a spring near the top. Upon disassembly, you will notice the clutch which is a white fabric/cloth/cotton appearance. This has to be replaced. Probably available in eBay. In my location, such spare part is not readily available and we have to make do with work-around (not necessarily technically right but as long as it works and for your info only). Things we try:, Stretch the spring, the idea is to put more pressure on the clutch when assembled back; roughen the contact portion where the clutch mates with the spool assembly; worst case scenario, forget the clutch, dab a drop of rubber adhesive on both sides of the clutch. In certain models/versions, it is possible that a slipping belt is causing the problem. In some instances, it could be the driving motor. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 18, 2007
Danmart
  • 291 Answers
SOURCE: FUNAI DVD/VCR COMBO
You need to replace all rubber bands inside the VHS.Vary difficult to find rubber band kit.If you use the TV in the heat, u must place a fan of some kind in the back blowing IN to cool the insides of TV. [AFTER U REPLACE rubber bands]
Posted on Aug 04, 2008
  • 333 Answers
SOURCE: Pye py90vg VCR will not play
There are 2 problems. On the botton of the machine you should replace the rubber drive belts. And on the top of the machine under the cover there is an idler wheel with a rubber wheel on it. that shoul be replaced too. Caution If you are doing this yourself please have the power cord disconnected. If you do not have the parts. It would probably be cheaper to buy a new unit, depending on the model. Because if the belts are worn then it is time for a complete service.
Posted on Dec 13, 2008
SOURCE: Emerson VCR/DVD player. A VHS tape plays in color,
Check on the dvd menu about the video format
Posted on Jan 07, 2010
Slow playback after recording.
Quality is definitely a factor here. Set tape speed to SP. Standard Play. It uses the most tape, and use a newer tape if possible.
You can also try converting to a newer format like MP4. This is the new standard for web videos. Older codecs might be an issue.
Sep 30, 2012 | Diamond Multimedia VC500 One Touch VHS...
Audio noise on some, but not all VHS tapes
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking would bring in the audio, but sometimes the video would get fuzzy. Get the picture right and the audio goes out. Switch to Linear (mono on some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
Goodluck..
Feb 16, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Older VHS tapes play 'sped up' on S-VHS
A couple of possibilities: 1. One of the machines had a audio & tracking head alignment problem. If memory serves, tracking pulses are recorded on the bottom edge of the tape, and if one machine's head is slightly off, then these pulses aren't being picked up.
2. Do both machines have 3 play/record speeds? Many machines had SP, EP, & LP. Some didn't have EP, and if your older tapes were recorded in EP, perhaps this would cause your problem.
Both of these possibilities might be way out in left field.
Perhaps you could have a friend try your old tapes in their machine- in short, narrow down the defect. Is it the older VCR and it's recordings, or is it some goofy problem on the new one.
Lastly, you might check the audio/tracking head- see if it needs cleaning. This head is just to the right of the rotating video drum assembly.
Jan 28, 2008 | JVC HR-S3901 S-VHS VCR
I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Jan 25, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
DRC 8335 Playing Back VCR Recordings in a Fast Forward State
I bought mine yesterday and am having the same issues. No solution listed in the user manual to fix this and I have a rather extensive VHS tape library that I was hoping to move to DVD using this unit. Unable to watch any VHS tapes taped on my Panasonic VCR and it seems as if the tape is slipping. Tracking buttons don't fix anything. I found a blank spot at the end of the tape and taped something and it comes out fine. Could this have something to do with it being a 6 head VCR? Tapes are in SLP mode.
Jan 08, 2008 | RCA DRC8335
VHS system malfunction
VCR's automatically detect what speed the present tape was recorded at. It only gives you a choice of speeds when doing the recording. If you are saying that it won't playback a tape recorded in one of the slow speeds, it is most likely because VCR's with more than two heads use different combinations of them in different speeds and the ones used for slow speeds are maybe needing cleaning. If this is the case, the vcr will seem to be playing OK, but the video playback will be bad.
Dec 25, 2007 | Goldstar GVR-DD1 VHS VCR
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Funai ZV427FX4 DVD Recorder/VCR Combo Logo
24 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
