Trying to prgram Westinghouse tv model eu24h1g1 for direct tv no code listed for this model
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes.There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices.After confirming this, check the sites linked here.Both the sites have set-up code list and set-up procedure to many popular brand remote controls.Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability?Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual.Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Posted on Feb 13, 2014
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
SOURCE: direct tv remote code
RC 64
Posted on Oct 07, 2008
budmrtn
  • 11361 Answers
SOURCE: need codes for phillips remote direct tv. tv
www.urc.philips.com
Posted on Nov 02, 2009
SOURCE: need tv codes to program direct tv remote. \r\nI
Try these codes:070,085,001,126,166,079,120 I hope that helps.
Posted on Apr 17, 2011
  • 98 Answers
SOURCE: I purchased a Westinghouse 32"
http://westinghousedigital.com/wordpress/wp-content/uploads/2010/05/Remote-Codes.pdf
That should give you the codes you need. Hope it helps.
Posted on Sep 06, 2011
Antenna set up, channel scan
Asker resolved own issue.
Mar 17, 2014 | Televison & Video
CODES FOR CHAETER CABLE REMOTE
Not sure what you want, if have that remote it should have a model on or inside it---Westinghouse TV is what is listed here===trying to program it or?
Nov 06, 2012 | Westinghouse W4207 42 in. HD-Ready LCD TV
WHAT THE CODE TO PROGRAM A WHITE-WESTINGHOUSE OLDER MODEL TV
Hello
Three digit universal remote codes for White Westinghouse TV are:
097/ 100
Four digit codes are:
0227
0279
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK
Aug 05, 2011 | Westinghouse Televison & Video
Can't progam my direct tv remote to operate my westinghouse 32''tv
Dec 27, 2008 | Westinghouse SK-32H240S Television
Direct TV remote, need code for Westinghouse Flat Screen 32" itsdon458@yahoo.com
Try these codes listed for Sony.  10080 11100 10111
 One of these should work.
Jan 06, 2008 | Westinghouse 16093 Remote Control
Remote code
DirecTV offers a remote code lookup tool, which I just used to find possible codes for my Westinghouse TX-42F430S; its first suggestion (the "most popular" code) didn't work. Clicking the "It's not here" button showed seven more codes, and one of them (11577) worked perfectly. Here is the full list of Westinghouse codes for DirecTV from that tool (as of 11/27/08):
Most Popular Code: 10885
Other Possible Codes: 10889 10890 11577 11282 10451 10000 11092
Nov 10, 2007 | Westinghouse 16093 Remote Control
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
