Question about Hasbro Scrabble Express Electronic Handheld Game
How to turn off scrabble express
I can't see how to turn off scrabble expresss. there is a on/new button but holding the button down wont even turn it off.
How do I update scrabble have been through all the procedure and it still won't connect to Facebook
Andrea
Hard to work this one our
What has scrabble on iPad got to do with Facebook.
The procedure to fix software glitches on an Apple iDevice is to double click the bottom button. Swipe all running Apps upward to quit them all. Then hold the Top Button and the Round button in for about 5-10 seconds. Shut down the e.g. iPad. wait till completed. Hold top button in for 5 seconds and iPad should reboot from clean IOS software. This fixes many annoying problems with faulty Apps etc.
Run iTunes on your computer once in a while and connect your iDevice. Do a backup or even a sync. That way if anything goes wrong you have an up to date copy.
Also.... stay up to date with updates as they can fix known bugs.
This can also be done via iTunes. Just plug the iDevice in to start the update "Download Only" then you can disconnect and come back later to perform the actual update.
Hope the advice proves useful!
TJ
Oct 30, 2014 | Apple Ipad I-pad
My htc 8s wont charge
Do not do a hard reset,you don't need to. Hold the power button down for twenty seconds and the phone will reboot itself.
Jun 13, 2013 | HTC Windows Phone 8S
How to change the password on Apple airport express ?
Unplug the AirPort Express from the power outlet and press and hold the reset button. While still holding down the reset button, plug the device into a power outlet. Hold down the reset button until you see the light flash green four times. Let go of the button and the device will reset itself. Wait the requisite 45 seconds and configure it with the AirPort Express Assistant or AirPort Admin Utility.
This performs a factory reset.
May 05, 2011 | Apple AirPort Express Base Station with...
Please could you tell me why scrabble worldwide wont load properly on my ipad thank you
1) you do not have enough room for more data/games/etc..
2) there is a problem with the game in general
Possible solution (might not work)
1) click and hold the power button (at the top) and the circle button at the same time for about 15 seconds so that it will restart.
var fctb_tool=null; function FCTB_Init_2091c2d2080e4329a2eacc6292f974fa(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_2091c2d2080e4329a2eacc6292f974fa(document['FCTB_Init_b7efeb6f168e4341b6cfe9051a9fbf0e']); delete document['FCTB_Init_b7efeb6f168e4341b6cfe9051a9fbf0e'] var fctb_tool=null; function FCTB_Init_3a467d85b6c84169a73e72c6ae372698(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_3a467d85b6c84169a73e72c6ae372698(document['FCTB_Init_5a3ccc9086ec42eb93502e24601c76ab']); delete document['FCTB_Init_5a3ccc9086ec42eb93502e24601c76ab']
May 04, 2011 | Gamehouse SCRABBLE® Worldwide excluding...
Phone doesnt turn on need help quick!!!!befor my mom kills me!!! lol
Hi try this : press and hold “3′, the “Green button” and “*” - Turn on and keep holding untill the phone fully restarts.You may need somebody to help you.
Rate me if it helped. Thanks.
Apr 13, 2009 | Cell Phones
My phone wont turn on its charged but wont even charge or turn on
Try holding down the top on/off button and the home button at the same time. Continue to hold down and within 30 seconds or so it should come back on. hopefully. good luck
Dec 30, 2008 | Apple iPhone Smartphone
Camera wont turn on/off
I went to another problem, knowing my camera was stepped on, I messed around with moving the lens part around, barley moving it, and then I tried holding the on/off button and the button to take the pics with, and then put in new batteries and it turned on. I would suggest doing that.
Aug 28, 2008 | Sanyo VPC-S500 Digital Camera
SANSA EXPRESS
Not sure but it could be dead, but dont worry till you do a hard reset by pressing and holding down the "select(Square button)"and "volume up" buttons.
I just got mine today and been looking through the sandisk forum.
Hope that helps bye :)
Jun 15, 2008 | SanDisk Sansa MP3 Player
Mp3
Have you reset it? Grab a needle or a end of a ear-ring and put it in the hole located right of the ear phone jack, once you hear a button being pressed down, hold for 5 seconds and then it should turn on. As for recongnization, try different USB ports on your computer.
Mar 12, 2008 | Memorex MMP8565 MP3 Player
Hasbro Scrabble Express Electronic Handheld Game Logo
75 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
