Question about Electrolux Washing Machines
Finding parts HI. I have Electrolux EIFLW55H with 4.7. During start of cycle, there is a rubbing noise (not grinding metal noise) as the unit turns until it fills up with water, then don't hear it any longer. Any thoughts on what is wrong and how to fix this ? Thx
  • 333 Answers
SOURCE: make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Posted on Apr 16, 2008
SOURCE: Loud Noise during spin cycle
I have a maytag that sounds the same way but washes and spins fine despite all the noise???
Posted on May 21, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washing Machine fills with water then just stops
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading for item number 11 for the lid switch and item number 20 for the lid strike (if needed). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can also cause more potential problems.
Posted on Oct 21, 2008
ldsaunders
  • 31 Answers
SOURCE: Weird rubbing or mild grinding noise when in spin cycle.
It sounds like the bearings on your tub are going. This is an expensive and difficult job to do. (approx $450 parts and labour and you may do more damage trying to take it apart)
Posted on Feb 12, 2009
  • 27 Answers
SOURCE: The washing machine started making a grinding
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Posted on Jan 15, 2010
Pump or bearing problem?
If this is a top load maytag, the pump bearing sleeve will rub the pump pulley and make a grinding noise. Replace the pump.
Sep 26, 2013 | Maytag Washing Machines
Not draining burning smell electrolux front load
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 25, 2012 | Electrolux EIFLW55H Front-Load Washer with...
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Grinding sound when turning
if its a grinding/knocking type sound then it could be the cv joint gone bad.the side that makes the noise when you are loading during turning(turning left you are loading the right cv joint and vise versa)that is the side the bad joint is on.it will happen whether or not your foot is on the brake.if the noise happens as strickly a grinding noise like when brakes are metal to metal when applying the brakes then it could be brakes need replacing.also have seen were if the inner fender is loose or oversize tire is on it can rub sounding like grinding.
Apr 08, 2011 | Nissan Frontier Cars & Trucks
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
Wont wring out clothes Model: EIFLW55H IW
sounds like the drain pump is either plugged or failing. Make sure to ID the part by looking at yours and checking the voltage. Here is the cheapest place I could find the part www.techray1.com and click on the guru guy then use the drop down menues to select your part...email me if you still need assistance
Jun 22, 2009 | Electrolux EW1000i Front Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
My GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Oct 21, 2007 | GE WDSR2080D Top Load Washer
Washing Machines Logo
10 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
