Question about Psion WORKABOUT PRO
How do i get the capital letter lock off - Psion WORKABOUT PRO
How to turn capital letter lock off
press the button that you use for a capital letter n itl go off
Jul 23, 2014 | RIM BlackBerry Cell Phones
Caps are on all the time
Press the
"caps lock" key once to take it off capital letters. If that doesn't work, get an external keyboard and plug it in and try it. That should do it.
Apr 08, 2014 | Compaq Presario CQ56-115DX Laptop
HOW DO I CONNECT MY APPLE IPHONE TO PLUSNET WIRELESS
To type capital letters, press the shift key which is the up arrow in the bottom left corner of the screen, and then press the key for your desired letter. If you would like caps lock, double-tap the shift key. Note that the caps lock will be deactivated if you change to the number keyboard or symbol keyboard.
Jun 23, 2012 | Apple iPhone (16 GB) Smartphone
KEYBOARD ONLY PRINTS CAPITAL LETTERS . HOW DO I RETURN TO LOWER CASE LETTERS ?
Try pressing the Caps Lock key, (the Caps Lock LED will then turn off) this will return the letters to lower case.
Jul 27, 2011 | Computers & Internet
I want to send message in capital letters i.e. in upper case. How I can do this
Hi!
On your keyboard, on the Left hand corner there is a Caps Lock key/button. Press that and try checking when you type if its all in Capital letters.
Hope this helps.
Jun 03, 2011 | Computers & Internet
The lower case letters are higher up than the capital letters capital letters are on a line but the lower case are probably 1/4 " higher
There is and adjustment for this if the rubber bumpers are not worn or missing. When you shift, the basket stops on a bumper. There is a locking screw that you loosen and turn the shaft with a screwdriver. When it all lines up lock the nut,. It is harder than it looks. Usually a Pro does this
Feb 07, 2011 | Royal Office Equipment & Supplies
How to type in capital letters on facit typewriter?
You did not specify if it was a manual or electric or the model, so assuming it is a standard manual or electric machine, push down on the shift key and hold it, then type your letter or letters. If you are typing everything in caps, press the shift lock key.
Aug 20, 2009 | Office Equipment & Supplies
Cannot use letters of my laptop unless use fn key but not capital
You need to press the NumLock key to get the keyboard to get back to alphanumeric - it has a symbol of a lock with a number 1 on it. A LED should also go out/icon in your tool tray should disappear as well.
Jul 05, 2009 | Acer NSK8458AN Keyboard
Capital letters
You can either turn on CAPS Lock or hold the shift key while typing. Have you already tried this?
Jan 30, 2008 | NorStar Refurbished OTM 1.x Billing...
Psion WORKABOUT PRO Logo
35 people viewed this question
Top Psion Computers & Internet Experts
Lee Michel
Level 1 Expert
Are you a Psion Computer and Internet Expert? Answer questions, earn points and help others
