Question about Coltene/Whaledent BioSonic BioSonic UC 100 Accessory Kit - Dental
BioSonic UC 100 stopped working
Is there a simple first step to look into my Biosonic uc100?
Monthly Cleaning instructopns for Whalewdent Biosonic UC 3000
Hi! this is Alex Walker expert to help you to analyse this issue for you call me on +1(518)348-9393
Oct 04, 2017 | Computers & Internet
Biosonic us100r
I don't see a question.
Dec 05, 2016 | Computers & Internet
My Samsung Galaxy Tab 4 is showing :mobile data are turned off. The page can be loaded once you connect to network" 2.Maps has stopped working 3. Memory is low. How do I fix these problems
fixing problems with a phone start with a good user manual of the phone and then reading each step in the book
go google and type in---user manual for samsung galaxy tab 4 phone -- there will be a pdf version or around 100 pages but it tells you everything that you can do , you can fix and trouble shooting
if you don't have a pc get a friend to download it for you
Oct 30, 2016 | Samsung Office Equipment & Supplies
What are remote codes for biosonic TV
2091,2049. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 28, 2015 | Televison & Video
Honeywell UC100E 1006 "snap-lamp" unable to unplug the lamp from the socket
Sorry that i cannot help you as this was some how posted in the TV area which is not your fault.
Dec 06, 2012 | Televison & Video
How i install uc browser for nokia 2690
looz its simple .bt as it is nokioa 2690 uc 6.3 wil support to ur mobile.
Oct 31, 2011 | Nokia 2690 Cell Phone
Why uc browser does not support in samsung B3210 corby txt
frnds i cant use uc browser in my corby txt b3210..plz help me........
Dec 07, 2010 | Samsung Cell Phones
Was washing ok until the last spin then it stop and uc lights are blinking what is uc?its does'tspinat all now
The "uc"code on the Neptune indicates a "continuous unbalanced circuit". Check to make sure that the weight of the clothing is distributed evenly in the tub. There can be a few causes for the generation of this code and you might want to consult an appliance technician for assistance. Bad shocks can cause this by permitting the tub to be out of balance, but you didn't describe any banging, etc. The tub displacement sensor could be at fault. The pump and pressure switch should also be checked for proper operation and to make sure there is no obstructions in those components. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune washer TI
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out a trying a fix If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium heavy loads and all work fine no unballance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Sep 30, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL Stops
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Sep 24, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Coltene/Whaledent BioSonic BioSonic UC 100 Accessory Kit - Dental Logo
149 people viewed this question
Top Coltene/Whaledent BioSonic Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Coltene/Whaledent BioSonic Health and Beauty Expert? Answer questions, earn points and help others
