Detail tape paper jam
There is a piece of paper stuck in the detail tape side that I cant get out
  • 388 Answers
Try tweezers.
Posted on May 11, 2014
I have a paper jam that i cant get to. The paper is coming out with a line that is crimped in the middle. I can hear paper rolling but cant see anything to get out. The paper that comes out has a line...
Check for any debris or any stuck object inside the unit, it could be a small piece of paper has left inside when you encounter any paper jam problem before.
Better to use a better high quality paper on your copier, it sometimes the problem like this happen because of low quality paper use, the paper roll inside and the paper cannot feed out properly out of the copier.
Let me know for further assistance.
Thank you for using fixya,
Jun 22, 2010 | Canon imageCLASS D860 All-In-One Laser...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Where can I take my Stylus Photo RX500 for repair? The paper feeder eats the paper on one side.
you probably have a tiny tiny piece jammed in the roller on that side. sometimes it gets stuck inside and you cant see it. take it apart and use tweezers to pull it out. usually its a small piece similiar to the leftover junk you get when you rip out a page from a ring notebook.
Sep 03, 2009 | Office Equipment & Supplies
Pulled off something while removing jammed paper
See if the printer works- if not take it back to the store, things should not fall off that easily. Nor taped in such a way that damages your printer. But, if you had the printer a while- Look to the other side of the printer and see if you see another piece like the other piece. Perhaps that will give you a clue as to where it goes. If this didn't help, describe what the piece looks like and where you removed the tape.
Please leave me a rating...
May 15, 2009 | HP PSC 1510 All-In-One InkJet Printer
Paper is getting jammed hence not printing
Sounds like somthing is caught in the left hand side try looking in it with a flashlight and see if you can see somthing stuck like a twistie tie/sticky label/ staple / sticky tape.... If its in far try using a ruler or a few pieces of paper stacked together to dislodge it.
May 06, 2009 | Lexmark Z2420 Printer
Oki B4540 keeps saying
You should certainly start by looking at the toner cartridge to see if there is any tape to remove. If there is no tape with a visible pull tab, check inside the printer to make sure that there are no pieces of torn paper stuck anywhere inside.
May 05, 2009 | OKI B4350 Laser Printer
Paper Jam
Try putting a piece of tape or something sticky on the eraser end of a pencil and try to work out the paper. Sometimes, you can use needle nose pliers or other long nose pliers to grab the paper and pull it out.
Dec 13, 2007 | HP Officejet Pro L7680 All-In-One Printer
Paper Jam/Kyocera C850/C850D
There will be a piece of paper stuck in there follow the instructions again opening every door on the left side. If there is not some paper the likely thing is that the paper sensor is jammed open or the light reflector sensor is dirty or the last thing is one of the sensors are faulty.
But I know these machines very well and the sensors rarely go faulty so I'm 98% sure there will be just a small piece of paper stuck in there. (It may be between the two doors or stuck behind a guide.
Oct 18, 2007 | Kyocera Mita (km-c850d) All-In-One Printer
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
