Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher paykel dishdrawer lid will not stay locked
Wash cycle begins but then goes to pause by itself. It seems that the lid disengages.
  • Fisher and P... Master
  • 3,247 Answers
Assuming this is happens with only one drawer - most likely controller is recongising some sensor problems. If the water inlet is faulty then it is waiting for water to get in. Alternatively, the sensor that tells it the drawer is closed suddenly misbehaves and confuses the controller which stops the cycle.
Posted on Feb 14, 2014
5 Suggested Answers
stephanos18
  • 144 Answers
SOURCE: Fisher and Paykel Double dishdrawer
when you start the unit let it run for a minute then pause it before it starts to fill and check to see if it's drained it's water if not then you have a drain fault cheers. fell free to Chat live if you want me to talk you through it cheers
Posted on Mar 27, 2009
  • 3247 Answers
SOURCE: Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Posted on Nov 10, 2009
  • 3247 Answers
SOURCE: my fisher/paykel dishwasher does not complete a cycle
It is possible the delayed start option has been set by mistake.
The way to cancel that would be to press the power button off and then on.
However, I am assuming this problem is with only one of the two drawers.
But I am not sure how much of the wash cycle is done before it goes to pause, eg. do you hear the water flowing in, do you hear the washer arm moving and throwing water around?
If it does not get to the stage of water coming in but you do hear some sounds as soon as the start button is pressed then it is likely the door seal is not setting properly which causes the dishwasher to stop.
Anything you see on the display or lights (if no LCD display)? Trying cleaning the door seal with a clean damp cloth. If problem still there then you need to get the door seal serviced. It is slightly sophisticated part with seal and two motors which require some expertise to replace.
Happy to guide you if door seal replacement is needed. Post me a comment on what you find.
Posted on Jul 14, 2010
Fischer and paykel dish drawer leaking
Replacing lid seals on the dishdrawer is not for the faint hearted.
In particular if you are replacing the lid actuator and motors that go with it.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=386&category_id=58
Apr 06, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel model no GW611 washes but won't spin nor lid locks
Sounds like the lid lock has gone bad. Check the wire connections to it and if you should need to order the lock, here is their website.
Nov 05, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel Dishdrawer-DS605SS F4 fault code
No temperature increase has been recorded when the element is on.
The element is not connected.
The element has gone open circuit.
Temperature sensor or electronics ADC has failed.
Oct 04, 2012 | Fisher and Paykel DishDrawer DS605FDSM...
Good morning, I have a F&P dishdrawer ds605i (i think!) single drawer intergrated front. I dont know whats happened to it. The last cycle it decided not to empty the water out, so i manually...
Hi
I guess the model no. you have sent is not correct,however given bellow are links from where you can troubleshoot your problem to your dishwasher which is related to your issue:-
http://www.ehow.com/how_7013603_troubleshoot-fisher-paykel-dish-drawer.html
Also check the bellow link to know a detailed idea when your F&P dishwasher wont drain or empy at the end of the cycle:-
http://www.ehow.com/how_4815751_unclog-fisher-paykel-dishdrawer-drain.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 28, 2011 | Dishwashers
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishdrawer leaves dried detergent and crud on
1-Go to diagnostic mode.
2-Press the Start /pause button until you get the display rd for Rinse Aid Dispense setting.
3-Have warm water readu in a kettle or a pitch.
open thedispenser to pull water in.
press the Lock button to turn the dispenser on.
4-Continue to pull water onto the dispenser holder so it can flush out all the resisdue.
5-When you feel that it is enough, press the Lock button again tostop it.
6-Press the power button to get out of this mode.
7-Start a Rinse cycle to completely flush out the residue from the inner tube to the sewage.
8 The next run you won't see the white stuff anymore providing that you will use the liquid not the powder...
Jul 03, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Turn on and off buy it self
If a Fisher & Paykel dishdrawer is having a problem, it will usually display a fault code beginning with a "U" or an "F". "U" codes are usually solvable by the owner by checking the definition in the owner's manual. "F" codes usually require a service technician. I can tell you from experience that if you have no idea what to do, you should leave this one to someone who does. It's very easy to cause more damage by trying to disassemble it incorrectly. Also, the DD603 utilizes a "smart tool" that enables a technician to use a laptop and F&P software to diagnose the problem correctly.
Apr 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel GW612 beeps before spin.
You have fault code 66 (01000010) Phase 6- Pressure Transducer (Ptx) Error - Frequency >90kHZ. In simple terms you need to replace the main "Motor Control Module" Cheers
Mar 09, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel double dishdrawer
pour some vinger in and run it thru a few cycle this will flujsh it out also if you have a hot tub supply store near you can buy a bottle of Foam Down and that will cut the bubbles down so you can wash again
May 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
172 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
