Question about Bernina 1008
I have a Bernina 1008. The thread is bunching up underneath when sewing. I've cleaned and oiled the bobbin area, rethreaded and adujusted the upper tensnion- the topstitch looks fine, it's lumpy on the bottom side like the tension is off. I've adjusted the bobbin tension, it pulls smooth. Could the timing be off? Any thoughts what else I can do? Thanks.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
Hello. Make sure the bobbin is not backward. It seems the upper tension is still not adjusted right. If the bobbin pulls smooth focus on the top tension. Good Luck
Posted on Feb 13, 2014
4 Suggested Answers
Mongo32
  • 111 Answers
SOURCE: I have a Bernina Activa 130. The bottom threads
bunching threads bunching means that upper tension or threading is wrong
Posted on Jul 08, 2009
RickE1
  • 202 Answers
SOURCE: I have a Bernina 1008 and I love it, but every
Hi, I'm guessing you have the bobbin in the bobbincase upside down and its turning the wrong way. Or the machine is not thread correctly. Possibly there is junk in between the tension discs at the top that the thread goes between. Just some thoughts.
Rick
Posted on Oct 08, 2009
  • 1564 Answers
SOURCE: My bernette 65 is bunching underneath. How do I resolve that?
Grasp the threads and hold them down when you start your seam. If it still happens make sure your thread is seated into your upper tension mechanisms. If that still isn't solving your problem... CLEAN between the tension discs with some sturdy fabric folded in half. (wax build up from threads can cause issues)
Good luck
Posted on Aug 05, 2012
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Bernina activa 130 tension loose after needle breaking into bobbin area
Is it the bobbin tension that is very loose? Try tightening it. Also check that the bobbin has been installed in the bobbin case, turning the correct direction and that the bobbin tension is threaded properly.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
If it is the upper tension that is loose and creating "thread nests" under the fabric, the machine is either misthreaded or possibly the thread is not seated completely in the tension disk.
Remove the upper thread from the machine.
ALWAYS RAISE the presser foot and rethread the upper thread from the beginning--verify the thread path is correct.
Set the upper tension to the midway point between high & low number (the factory standard--although it may need tweaking later for your particular machine).
Retest your machine. Hopefully, the issue has been resolved. If not, it may need service.
Tutorials Urban Threads Unique and Awesome Embroidery Designs
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Oct 03, 2016 | Bernina Activa 130
Thread bunches up underneath
are you sure your needle is in right? flat side to the back.. Also, have the needle thread and the bobbin thread together at the beginning of the seam. Pull them behind the pressure foot. Put the tension on the red line of the top tension dial. Make sure your bobbin is unwinding in a clock wise motion. I love Bernina, they are the best sewing machines I have ever used...
Mar 24, 2014 | Bernina Sewing Machines
Turned machine on, started to sew(about 4"), machine beeped, screen started flashing off & on, then it went off. Will not restart. Tried a new cord and that wasn't the problem
Look at your seam. If you have a bunch of balled up thread underneath the seam, part of the problem is operator error. Always always grasp the thread end while beginning the seam. I suspect that the thread gut bunched up under the material and caught up in the bobbin/shuttle area.
Remove the fabric, unplug the machine... get into the bobbin area, remove the bobbin, and if necessary clean threads caught up in the bobbin race/shuttle. reassemble and replace the bobbin... turn on the machine. Try again.
Nov 01, 2013 | Bernina Artista 170
Good luck
Aug 04, 2012 | Bernina BERNETTE 65 Mechanical Sewing...
I have threaded up my machine and have started to sew. The thread on the back of the fabric keeps catching and bunches up. What's going wrong?
try a new needle
keep a check on the thread take up lever that the thread doesn't come off of it
rethread the machine to make sure that the thread isn't catching on anything
clean under the needle plate for loose thread or lint & in the bobbin area also
make sure the bobbin is inserted correctly
Aug 04, 2011 | Bernina 1008
Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Sep 05, 2009 | Sewing Machines
My Bernina 1530 stitches are faulty - with loops underneath, even though it looks ok on top. When I remove and rethread the bobbin, the stitches are ok for 6-12 inches then start looping again. I tried to...
This is almost always indicative of an upper tension problem.
First, make sure you're using a good quality thread. If you're using thread that's not of European manufacture, you're probably filling your tension assemblies with little fuzzies. Coats and Clark Dual Duty is the most notorious thread for causing tension issues. If you have a bunch of this thread: throw it away or use it for hand sewing.
Turn your machine off, and use some canned air to blow out your upper tension assembly. (It looks like a couple of little cymbals inside the thread path.) Set your tension dial to 4.5.
When threading, right before you actually thread the needle itself, and with the presser foot up, "floss" the thread back and forth by holding the thread at the top by the spool with your right hand, and down by the needle with your left hand. This will ensure that you force the thread into the tension assembly.
Also ensure that your bobbin is oriented the right direction, but this would be a less common cause for your symptom.
If none of these fixes work, you probably need to have your tensions professionally calibrated.
-R
Mar 04, 2009 | Bernina 1008
Sewing Machines Logo
135 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
