Question about Radio Communications
D104 wiring key the radio all works fine expect low audio imp mistach
  • 60 Answers
TUG 8, TUG 9, TUP 8 or TUP 9? What radio? If it's a pre-amplified or power mic, there is a screwdriver adjustment under the base and a 9 volt battery in the base. The battery could be dead or the mic is turned down. If it is not a preamplified D 104, it wont be loud unless you run it on a Tram or Browning Tube Radio that accepts a high impedance mic. I hope this helps. :-)
Posted on Feb 21, 2014
4 Suggested Answers
Mechanic688
  • 204 Answers
SOURCE: mic wiring
Hello, In case you haven't found it yet, here is for a 2510/ which is a cousin of a radio.
1 - Modulation/ Audio/ White
2 - Ground/ Shield
3 - Transmit/ Red
4 - up button/ NC
5 - down button/ NC
Thats if the D104 is a 4 wire, Mechanic
Posted on Nov 05, 2008
  • 32 Answers
SOURCE: wiring diagram for d104 m6b
1-White
2-Shield/Blue
Posted on Mar 29, 2009
  • 39 Answers
SOURCE: how do i wire a d104 desk mic to a madison base
You don't mention if the Madison is a 4 pin or 5 pin also you don't mention if the D104 is a 4 wire or a 6 wire microphone so this will be rather lengthly of an answer so if I help you could you atleast do the rating for me ? So here goes 4 pin / 4 wire 1]SHIELD 2] WHITE 3] RED 4] BLACK....O.K. 4 pin 6 wire 1]SHIELD & BLUE 2] WHITE 3] RED 4] BLACK YELLOW NO CONNECTION.....Are you with me so far ? Half over 5 pin 4 wire 1] WHITE 2]SHIELD 3] BLACK 4]N/C 5] RED.....5 pin 6 wire 1] WHITE 2] SHIELD&BLUE 3] BLACK 4]N/C 5] RED.I hope this helps you GOOD LUCK and have a good day Dan.
Posted on Jul 12, 2009
Testimonial: "THANKS ALOT IT WAS VERRY HELP FULL"
I have a none amplified D104 G stand it came off my TRAM D201 IT has a two center leeds that's shielded I know this will work on my cobra 29LTD but I don't get it please help
First, you have to replace the cable as you will need a minimum of 4 wires, 2 of them for the transmit and receive switching, and a shielded cable for the audio. It would be nice to have another as the common for the TX/RX switching but the shield is commonly used for this.
You will need to re-wire the switch in the candlestick to allow switching from RX to TX.
Google "D104 to cobra 29 mic wiring" and you will find many hits for this.
Your microphone was not intended to work with this style of radio. To save a buck, the CB manufacturers removed a 50 cent relay to do the transmit/receive switching. You can see what happens when you remove the microphone when you are listening to the Cobra. It'll stop producing any sound. This won't happen with the Tram,
Also, you may have problems with the microphone as it is high impedance as indicated by no transformer or preamp in the base of the microphone. This may be a problem as the Cobra has a relatively low impedance input.
Aug 07, 2016 | Cobra Radio Communications
Astatic d104 wiring for Yaseu ham radio
( 9 Stand ) Astatic D104 to Yaesu FT 990
Pin 1 is White
Pin 2 is Red
Pin 7 is Shield/Blue combined
Aug 12, 2014 | Radio Communications
Microphone wiring
the rf power going out is geting inducted on the wires of the mic.try using some ferrites close to the coax on the pl259 connector and on the mic wire itself.
Mar 01, 2014 | Radio Communications
Want to use astatic d104 mic for motorola maxtrac two way radio not a cb radio
With using a D-104 on a Maxtrac, you will probably need an audio amplifier.
Tom
Feb 13, 2014 | Radio Communications
148 mic wiring white d104
five pin /4 pin? (white D-104?)
five pin= 1-audio,2-shield,3-RX,4-comm,5-TX
4 pin=1-shield-comm,2-audio,3-TX,4-RX
Jan 03, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
When i keyup my d104 mic on cober 148 gtl ihear feedback squeal.but the d104 work good cobera 2000 gtl
try to keep the mic away from the radio speaker.check to see if its turned up to high.check your mic gain to make sure its like 1/2 open.If these fail then you could solder two 0.001 ceramic disc capacitors from the audio to the shield wires about 3" apart.then on the audio wire in between the 2 caps solder a 4700 ohm 1/4 w resistor.this should work.
Nov 09, 2013 | Midland 1001Z 40-Channels Base CB Radio
How do you retrofit a 4 pin D104 to a 2 pin model?
A two pin does not use a Push To Talk circuit so one wire you want is the Audio wire and the other is the ground wire.
Aug 31, 2012 | Astatic D104M6B/4B Model D104 Amplified...
I have a uniden Grant like to wire up a 4 wire D104 the mic has white black red shield
Wiring 1 4 pin D104 mic to a Uniden Grant CB is as follows -
  • Pin 1 - Shield - Shield
  • Pin 2 - Audio - White
  • Pin 3 - Transmit - Red
  • Pin 4 - Receive - Black
Regards, Tony
May 05, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
Im trying to wire a astatic d104 m6b to a galaxy 949 mobile can you give a color code for what color wire goes were?i have black white red blue and a bare wire thank you.
This works for any mic.
dont worry about color codes. look at the switches.. there will be a common on both poles of the d104.. those need to be tied together to grnd. pin 1 on mic . the others d104 on n/c side is your rx. pin 4... the n/o one will be your tx pin 3 the other n/o will be audio and will have a wire from the mic element also on that pole of the switch. pin 2..
Sep 25, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
Mic wiring
2 - Ground/ Shield
3 - Transmit/ Red
4 - up button/ NC
5 - down button/ NC
Aug 30, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
