Question about Jandy Pool & Spa
I have a jandy 7300 pool contriol system and the fuse on the PCB kept blowing out and the system does not come on. what do I have to do to get the system working?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Unplug all aux wires put one on at a time until it blows fuse then check that aux might be bad pump or bad wire
Posted on May 08, 2014
CNC65
  • 15 Answers
SOURCE: Jandy Aqualink - Rs, button control red lites on contriol panel
HAVE YOU HAD ANY LIGHTNING STRIKES?
Posted on Nov 06, 2008
  • 22 Answers
SOURCE: Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
Posted on Feb 18, 2009
SOURCE: Jandy Aqualink RSO301 keeps blowing fuse
Great discovery! You're welcome.
Could you please take a few and rate my assistance.
thanks...
Charlie
Posted on May 27, 2009
  • 366 Answers
SOURCE: Jandy aqualink rs4: pool has been winterized with
the only thing you can do since the jandy does not have a "winter" mode is switch the valves off. Once you have the valves in spa mode, there should be a toggle switch on the valve actuators. You can set the switches to the middle position and that will lock them in that position. You will probably have to re-winterize the pool lines.
Posted on Nov 14, 2009
SOURCE: Message 'LOW PRESSURE' on my Jandy LX pool heater.
This isn't a solution, but a question after having the same problem and doing some troubleshooting. I removed the water pressure switch in the heater and turned on the pump and water flows nicely out of the copper tube for the water pressure switch. Next I replaced the pressure switch and removed the two wires and shorted them together, being as a switch is either on or off, shorted or open. I confirmed that the short is seen at the connector going into the control panel. I still have the low pressure light blinking. What now?
Posted on Jul 24, 2010
Jandy Aquilink control panel keeps tripping circuit breaker
turn off heater if it still happens mark all auxs remove all then try again if it doesnt blow fuse plug 1 in at a time until it does thats whrer your problem is
Aug 16, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I get no power indications to my Aqualink. I checked the circuit breakers, Any idea what is going on?
check back of PCB board fuse might be blown if keeps blowing fuses unplug all auxs then plug in 1 at a time till it blows thats whats wrong or check powersupply should be 24 volts ac on back board
Sep 23, 2012 | Jandy AQUALINK RS TELELINK KIT
Ho do I turn on the backlighting on my Jandy Handheld remote?
It's under Equipment, System Settings. When I first got mine, it kept losing its configuration and wouldn't connect regularly to the base unit. I had to change the wireless channel it fixed both. My pool builder was useless. "KB Custom Pools" Austin, TX
Aug 22, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy PDA-PS4 lost link to salt system?? There is no more
go to system setup find aqua pure up setting from 0 to something and it will apear
May 27, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
My jandy pool control panel has gone dark as if it has no power. is there a fuse or something of that nature that i can check?
check the breaker that is marked rs in jandy service panel first.Then check the red terminal bar in the upper left corner of service panel. It may be unplugged or have loose or broken wires.then check the red terminal bar on the inside remote
Oct 01, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
thanks...
Charlie
May 26, 2009 | Jandy AQUALINK RS TELELINK KIT
No power at the power panel( Aqualink RS8)
if unit comes on write down all auxs then remove plugs replace fuse turn on then plug one in at a time till it blows then you know which auw then see if wires are burnt
Apr 25, 2009 | Jandy AQUALINK RS TELELINK KIT
Pool & Spa Logo
66 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
