Question about Bissell Lift-Off Deep Cleaner 94Y2
Bissell lift off pet wont spray solution
Wont spray water or solution from hand brush
SOURCE: Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Posted on Jul 14, 2008
SOURCE: My bissell pro heat power brush won't spray from the floor unit
my bissell quicksteamer wont spray water
Posted on Jan 24, 2009
  • 4 Answers
SOURCE: Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Posted on Jun 07, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 231 Answers
SOURCE: My Bissell Pet Eraser brush only rotating on the
it sounds like something is backwards. the brush should only rotate when using it on carpet, it should never rotate on the bare floors. check the belt for propper installation
Posted on Jan 03, 2010
Water wont spray
Hello, this is Ava with Think Crucial.
You can watch the step-by-step video for Troubleshooting assistance on no spray issue:
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 30, 2016 | Bissell 9200P ProHeat 2X Pet Upright Deep...
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My bissell proheat 2x 8920 has poor suction and wont spray water
take a tooth brush to the very back of the roller and u will free the dirt in the small holes at back
Mar 22, 2013 | Bissell ProHeat 2X Upright Deep Cleaner,...
Bissell proheat 2x pet won't spray water or **** dirty water up
A belt may have broken, there are two which drive the rollers. Remove tank, turn over and have a look behind the brushes. Check the manual for how to find and replace.
Feb 13, 2011 | Bissell ProHeat 2X CleanShot Bagged...
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a 3760 lift off bissell. Replace the torn
Did you get the right belt size? The belt you should have bought is this one:
Bissell 3760 Belt
Nov 08, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Bissell Lift OfF Brush Roller Stops Rotating
They make the worst machines, the rollers are cheap and they make it so you cant take them apart to clean them. You don't want a dyson either, they aren't any better for pets. With all that hardwood floors you should get a good canister vacuum, sebo and miele are the best.
Aug 24, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell lift off pet-no suction through base (hose is fine)
I had a similar problem with mine. When you take the collector container out, if you reach your hand up, you will fill a round, plastic piece. Gently turn it and the piece pulls out. On the outside of the piece is a foam filter that may be plugged. There is another filter underneath the collection container in a pull-out drawer. Both filters can be washed with cool water, allowed to dry totally, then replaced. I understand that both of these filters need to be washed "frequently". It worked for me, hope it works for you.
May 08, 2008 | Bissell 37604 Lift-Off Pet Bagless Upright...
Bissell Lift-Off Deep Cleaner 94Y2 Logo
29 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
