Question about Hoover S3765-040 WindTunnel Bagless Canister Vacuum
Beater bar stopping on carpet - Hoover S3765-040 WindTunnel Bagless Canister Vacuum
5 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: Beater bar stalls
Sounds like the belt to the bar isnt turning properly or could be clogged up with dust or need replacing.
Either way youll need to open up the sole plate and check the condition of the belt by the rolling brush bar. Also check the condition of the brush bar to see if it isn't clogged up with general dirt and hair.
Posted on Apr 19, 2008
  • 66 Answers
SOURCE: Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Posted on Jan 24, 2009
SOURCE: Beater bar doesn't go around when vacuuming
try getting a new belt
Posted on Mar 22, 2009
  • 231 Answers
SOURCE: the beater bar has stopped turning. Suction fine
probably a broken belt. part # 38528-033
Posted on Jan 03, 2010
DC 07 I can stop the beater bar with my hand so can the carpet it can be started by spining it can I fix this
Remove and clean the beater bar, especially under the end caps where fluff and hair builds up a adds brakes to the brush. Your belt may need replacing as they do stretch.
DC 07 Google Search
Dec 28, 2016 | Vacuums
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
I have a Hoover Windtunnel vacuum cleaner and new high pile carpet. The vacuum cleaner will not move forward without extreme effort. I have been told that I need a vacuum without a beater bar and that...
you can adjust the height on some vacumes like for bare floors and medium nap it will adjust how far the beater bar is from the carpet see if your is adjustable
Apr 11, 2011 | Vacuums
My dyson dc17 will not roll across the carpet, because their is too much suction.?
Turn on the beater bar with the gray button next to the red power button. The powered beater bar will "propel" the vacuum across the carpet.
May 02, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
The beater bar on my Dyson won't turn. The vacuum runs and suctions but the bar won't turn and the belt is not broke. The beater bar did get a carpet fiber caught and wrapped around it which stopped the...
The belt doesn't have to be broken to make the vacuum not work correctly. If the belt is stretched the vacuum won't operate the way it is supposed to. You can get replacement Dyson Belts here:
Dyson Replacement Belts
Dec 06, 2009 | Vacuums
Vacuum won't pick up any dirt - there's no roller marks when vacuuming carpet. Roller does turn and filters are clean.
When you turn the roller, you should feel some resistance from the belt. Remove the base blate that surrounds the beater bar. Check the belt. Take care in removing the beater bar, so you can get it back in the same way it comes out. Clean the beater bar while you have the bottom open. If you remove the beater bar to replace the belt, take the time to inspect the cavity behind the beater bar where the vacuum picks up. That is where vacuums usually stop up. Reassemble the vacuum. If necessary, slip the belt over the motor shaft and then slide the roller undre the belt. Install the beater bar back in the sockets and replace the base plate.
Best regards,
--W/D--
Aug 12, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Beater bar not engaging,
The belt is in tact, but the beater bar will not rotate
Jan 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Beater bar belt too loose
You need a new belt, they stretch after awhile and will slip.
Apr 07, 2008 | Vacuums
Hoover S3765-040 WindTunnel Bagless Canister Vacuum Logo
27 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
