Question about Sony Bravia KDL-40S4100 40 in. LCD TV
Left half screen freezed
Hi there, I'm having this problems with my TV. What happen is that after an hour of being turned on it freeze the left half of the screen showing vertical lines of different colors. I read on the internet that this could be a problem with the T-Con Board, almost all the forums agreed with that so I decide to buy this board and replace it, but unfortunately it didn't work, I replaced it and turn the TV on and it happen as usual. I contact sony by chat but the person who was helping me actually wasn't a person but a machine and the solution that it proposed me was very unhelpful (told me to turn my TV off and wait 60 second to turn it on again). So given this, I wonder if you can help me anyway, I'm very frustrated with this problem, I can't even watch TV because of this. Thank you very much for the help
    Top Expert:
  • Sony Master
  • 74,198 Answers
This type of fault can occur with a faulty ribbon cable [LVDS]; that connects to T'Con to display panel. Check it too. If you wish to get some details; check the site linked here.Viewing it in "Mosaic" will make surf easy.
Posted on Feb 13, 2014
  • Helmuth Sequeira Feb 13, 2014
    Thanks, in case that didn't help, what else can I try? thanks again
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: vertical flickering color lines instead of pictures
Soory man there is no deflection yoke or vertical output IC in a plasma TV set.LOL This person has a problem with whats called the substain power supply or bad caoacitors in the main supply. there is also a possibility that the set has a bad tuner. Only performing test on the set will determine the problem.
Posted on Mar 23, 2007
mistersony
  • 320 Answers
SOURCE: Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
Posted on Oct 18, 2008
SOURCE: different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Posted on Sep 10, 2009
Are trailer is only a couple of years old and we have only used it a few times - twice when we have used it we left the air conditioning running and left the trailer for a few hours and come back and it is...
Here is what happening . This has nothing to do with you having it on while you stepped out for a few hours. The unit needs to be cleaned/ filters/screens/fins/coils. This problem would of happened even if you were in the trailer as it was running. The issue is after a while, sense it needs to be cleaned it loads up and then starts to freeze and then once it starts to freeze coils etc... it then starts only blowing warm air. When you turned it off, and let it set for a while, reason it started working again, is because the ice that built up defrosted some to have unit operate proper again. Solution is to clean the unit good. Thanks Mike from fixya.
Jul 31, 2011 | Dometic Rooftop RV Air Conditioner
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My phone wont turn on properly. I try to turn it on and it freezes. It gets as far as the screen that says Nokia then the screen with 5 little dots that flash back and forth then it freezes on the second...
For resolving your Nokia N900 problem, I recommend a firmware replacement to reinstall the system software. Once these devices start acting silly, this is generally the way to fix them.
Full instructions and software are available here.
I hope that helps.
Feb 15, 2010 | Nokia N900 Smartphone
Screen gets fuzzy and freezes
i found that pushing down on the left of the screen (bottom if its opened) will stop it from doing that for the most part, my phone does it too, probably a loose internal connection, or at least it was, untill it stopped turning on completley...
Jan 28, 2010 | Samsung Gravity SGH-T459 Cell Phone
PS3 went from a "snowy" screen to a black screen. HELP PLEASE!!
hi..
Two or more things, first make sure you have your audio vidio cables correct
Yellow= Video
Red= Audio right
White Audio left
Also make sure that the tv matches the input your cables are connected into. I would make sure the restart the PS3 to make sure the video is good (after checking the tv input)
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
My Creative Zen started freezing a couple weeks ago. I would press the restart button at the bottom left and that seemed to solve it. Now though, when I turn it on, the Creative Zen welcome screen comes...
It sounds like the hard drive is damaged I have a archos 605 wifi it froze up on me so i turned it off and turned it back on and it wouldn't load pass the archos welcome screen come to find out my hard drive was damaged.Hopfully yours is still under warranty otherwise you'll have to send it in and pay to get it fixed but i would say the hard drive is damaged.
Nov 28, 2008 | Creative Labs Zen Touch MP3 Player
Archos 605 wifi freezes
Mine kept freezing alot, and now the on/off button wont work. I can only turn it on with the docking station.
Jun 14, 2008 | Archos 605 WiFi Digital Media Player
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
