Question about Hoover S2571 Quick Broom Bagless Stick Cyclonic Vacuum
Which way does bag go in - Hoover S2571 Quick Broom Bagless Stick Cyclonic Vacuum
How do I, get the outer bag off to replace it.
Debby,
Do you have a bag dock that holds your paper bags? If you do, squeeze the bottom of the part that goes around the bag opening so that you can remove the hinged part and then you can spread the first part & take it off & then remove the bag. If you do not have a bag dock, there is a "U" shaped metal clip that goes over the opening on the connector assembly. Remove that clip & that will allow you to remove your bag. Hope this Helps!
Jan 19, 2015 | Oreck XL Ultra Bagged Upright Vacuum
How do I remove outer bag of oreck vacuum cleaner XL 9000W and how do I clean it? Removable bag broke and outer bag filled up with dirt.
If there is a bag dock on it, seperate large part of bag dock from smaller one, by squeezing bottom of bag dock to release tabs from larger one. Pull smaller part of bag dock apart and off of vacuum. Bag will now release from hole. If there is no bag dock, there is a metal piece around hole that is holding other bag on.
Jul 08, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Why cant I get the bag to stay on?
sounds to me that the tube the bag connect to is broke or as got hole in it.
Aug 22, 2012 | Vacuums
I have an Oreck XL 2310RS. What bag number do I need for it? Thanks.
All oreck uprights take bag type CC. I would Recommend buying oreck brand bags. they have the only patton on the bags. off brand bags will work but they will leak and tear and break.
Sep 08, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I need to remove the bag top to install a new bag hanger. I can't figure how to release the bag top from the bag.
If i understand you correctly all you do is mash the clip were the bag connects to the bag holder
Aug 08, 2011 | Kirby Generation 3 Bagged Upright Vacuum
My electrolux vac shut off for a full bag. After replacing the bag the vac won't start and the bag full light stays on.What should I be looking for to resolve my problem?
If the suggestion that renevacdoc did not work, it is most likely that your valve assembly(full bag control) has gone bad and needs to be replaced. You will have to take your vac to the Aerus/Electrolux dealer/service store for repair.
Joe
Nov 07, 2009 | Electrolux UltraLux 2000 Bagged Canister...
DUST NOT COLLECTING IN THE DUST BAG
sounds like the bag if full and the is coming out from around the bag.make sure the bag is in correctly and tight
Jan 07, 2009 | Kenmore Progressive Bagless Upright with...
Oreck XL Leaks Dirt At Bag Entrance
do you use a docking station to put your bag on or is it just a push on bag? also when you turn on the vac with an empty bag in it, does the outter bag blow up?
Dec 18, 2008 | Oreck XL2200 Bagged Upright Vacuum
Vacuum bag busted
Greetings from GoVacuum.com,
Yes, you certainly can take off the outer bag of your Oreck and wash it in the washing machine. You DO NOT however want to put the bag through the dryer!!!!! Just hang the bag outside, and let it air dry. It is important to make sure that the bag is 100% completely dry before you use the machine again. If the bag is wet, it will cause dirt to turn to mud in the bag, and probably cause a foul odor when you use the bag.
There are 2 different types of bag systems with Oreck vacuums. The one pictured below is the older style that uses a metal clamp to hold the bag in place. The newer docking system, will be a white plastic clamp that holds the outer bag in place. They both will be removed the same way however. Simply take a screwdriver and pry off the clamp;
Once you have removed this clamp, simply pull the outer bag off. Once it has been washed, and the bag is 100% completely dry, put the outer bag back over the bag housing as far as it will go. When you put the clamp back on, it is imperative that the clamp go behind the plastic ridges, to ensure that it is tightly fastened. If the clamp is not put on correctly, this will cause the inner paper bag to fall off during vacuuming. Make sure that the clamp is in the right position when putting the bag back;
If you have any further questions, please feel free to email them to me. I really enjoy sharing my knowledge an passion about vacuum cleaner, and vacuum repairs. We do stock all Oreck parts, so if you need any parts, please let me know.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Oct 15, 2008 | Oreck XL2200 Bagged Upright Vacuum
Kirby
kirby style 2 bags if it is indeed a bagged unit, some where special order with what is called a shake out bag, if your outer bag has a short zipper with a cloth pocket it is a shake out bag in which you take the assembly loose from the machine and open the bottom of the metal empter and take out side and basically shake out the dirt. and use the pocket to help get out the dirt. but most of these machines did take a style 2 bag in which you unzip the outer bag and pull the paper bag away from the tube and reinsert new one onto tube and finally zip up bag
Mar 28, 2008 | Vacuums
Hoover S2571 Quick Broom Bagless Stick Cyclonic Vacuum Logo
49 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
