Question about D-Link DIR-615 Wireless Router
Tablet says authentication problem even though signal excellent
Our tablet reads excellent signal but when I type in security key password it will not let me get on internet with my android tablet it says authentication problem Our computer and one of our tablets work just not this one
    New Friend:
  • 22 Answers
Switch router off and un-plug for 30 seconds. Re-start tablet.
Posted on Nov 07, 2014
  • 26 Answers
You may need to go in to your router bios it may have something to do with the setting
Posted on Feb 13, 2014
I have a Dragon Touch tablet. won't connect to wifi after WEP is entered and accepted/saved.
Are you still using WEP security? Most devices today no longer use WEP as it is inadequate for serious security. Most devices today are using WPA2 security. If you are no using the proper security you will get an authentication error even if the password is correct.
Dec 25, 2014 | Dragon Touch Tablets & eReaders
Why does my tablet keep saying authentication problem when trying to connect to wifi???
Is this an older tablet by any chance? Some wifi cards on older tablets will not support newer security protocols like WPA-PSK without a software update. An authentication problem can also be caused by mis-typing the key or passphrase for your network, or by having chosen the wrong type of security protocol when asked to join a network. Try deleting the network connection you have already tried, and then rebooting your tablet and let it discover the network again. Make sure you pick the right type of network security protocol for the connection when you try to connect and recheck the key/passphrase after you type it before hitting 'connect'.
Dec 03, 2014 | Computers & Internet
I am getting "Authentication Problem" with WiFi on 2 tablets - excellent signal. Accepts the security code and will hold for a minute or so.
I see three points:
1. check if the password of the router is the same you have signed in the wifi-account of your tablets - it's typical that a wrong password is prompted with no error message.
2. check if the wifi-protection of your router has the same type (WPA, WPA2) as your tablets use
3. check if the router accepts new wifi-devices, sometimes there is a checkbox "only known devices can access via wifi"
greetings, bernd-steffen
Oct 12, 2013 | Android Tablet PC
Reset password on wireless router
That more than likely mean you have put the password in wrong or you are using the wrong authentication type.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
Jun 08, 2012 | NetGear N300 Wireless Router
Can no longer connect to home wireless intranet. Says I'm connected but when I try to get on it says I'm not. Yellow triangle w/black ! in it. Wireless light on computer base is constnatly
AuthenticationThat means you probably don't have the password or theAuthentication Type set correctly.
May 29, 2012 | Acer Aspire 5742Z-4200 Notebook
Dell vostro a860 won't connect to internet
Why not? Do you have the wireless turned on? Did you put the correct password in?
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
If you put the wrong password in, it will never connect. it will keep trying to connect but never will.
Authentication
That means you probably don't have the password or the Authentication Type set correctly.
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 28, 2012 | Dell Vostro A860 Notebook
Dell inspiron 8000 password authentication system
Are you talking about the authentication process on trying to connect using wireless?
May 10, 2012 | Dell Computers & Internet
Cannot get the internet to work
May 08, 2012 | Computers & Internet
How to secure my internet connection via smc router
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
IF THIS ALL DOSEN'T WORK TRY THE FOLLOWING:
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Aug 03, 2010 | SMC Barricade 7004VWBR Wireless Router
D-Link DIR-615 Wireless Router Logo
173 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
