Question about Brother MFC-290C Printer
New black ink cartridge
Need to remove old cartridge and install new one (which I have now).
  • Brother Master
  • 783 Answers
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link: Replace the toner cartridge Brother
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Brother Printer Support
Posted on Feb 19, 2014
Mix-it-up
  • 832 Answers
SOURCE: Won't recognize new cartridge
see here: http://www.fixya.com/support/t192382-near_empty_yellow
Posted on Sep 07, 2007
Mix-it-up
  • 832 Answers
SOURCE: new ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Posted on Jan 28, 2008
  • 12 Answers
SOURCE: Black ink not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Posted on Feb 02, 2008
SOURCE: Printer Brother DCP115C 8 months old Won't accept a new ink cartridge
The printer says that when you use other brands of ink other than recommended. I get it happening all the time. When it happens just press Stop/Exit and the printer will work fine.
Cheryl.
Posted on Jul 13, 2008
SOURCE: Black ink cartridges not working.Have tried two
I had inserted a new black ink cartridge in my DCP - 585CW Brother printer and it does not print, the coloured ink workks but not the new black ink?
Posted on Dec 21, 2009
New Colour and ink Cartridges are installed, but printer will only print in black
Hi Peter
Old ing goes hard and blocks tiny pores
Remove the new ink cartridges and clean old ink away with methylated spirits.
Leave rag in around heads for awhile to soften up ink.
Clean gold contacts also with methylated spirits
Apr 07, 2015 | Office Equipment & Supplies
Tip
How to replace the ink cartridges on a Dell All-In-One 948 Inkjet Printer 1....
1. Turn the printer on.
2. Lift the printer unit.
3. The ink cartridge carrier moves and will stops at the loading point unless the printer is busy.
4. Press down on the ink cartridge lever to raise each ink cartridge lid.
5. Remove the old ink cartridges from the printer.
6. If you are installing new ink cartridges, then remove the sticker and transparent tape from the back and bottom of each ink cartridge.
Note: If you are wanting to print photos you will want to install a photo cartridge along with the color cartridge. Also if you are switching between the photo and black cartridge but they still have ink in them be sure to store then in an air tight container so they do not dry out.
7. Insert the new ink cartridges. Making sure that the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier.
8. Snap each lid closed
on Apr 01, 2010 | Dell 948 All-In-One InkJet Printer
I just purshased a lexmart pro 705..How do you install the ink???please help
Replacing ink cartridges
Make sure you have a new ink cartridge or cartridges before you begin. You must install new cartridges immediately
after removing the old ones or the ink remaining in the printhead nozzles may dry out.
1 Turn on your printer.
2 Open the printer.
Note: The printhead moves to the cartridge installation position.
3 Press the release tab, and then remove the used ink cartridge or cartridges.
4 Install each ink cartridge. Use two hands to install the black cartridge.
Note: Install the new ink cartridges immediately after removing the protective cap to avoid exposing the ink to air.
5 Close the printer.
The setup guide is on theCD you received with the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | Lexmark Office Equipment & Supplies
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
How do i remove old printhead and install new one
Replacing the printhead If your printhead is damaged or broken, you may replace it yourself.
  1. Make sure your printer is turned on.
  2. Open the printer access door by lifting from the recessed hand-holds on the sides of the unit. autourg00977009id2130369.jpg
    The printhead moves to an accessible position for handling the ink cartridges. The ink cartridges are seated in the printhead.
  3. Pinch the latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
    caution.gif CAUTION:
    Insert the ink cartridges into the newly installed printhead as soon as possible to prevent any drying of the ink.
  4. Unlatch the printhead by lifting the rectangular latch on the top of the printhead.
  5. Remove the old printhead from the carriage .
  6. Remove the new printhead from its bag.
    Do not touch copper contacts on the printhead, as this may damage it.
  7. Remove and discard the black plastic casing and the orange protective cap.
  8. Place the new printhead into the carriage.
  9. Push firmly against the target label on the printhead until you hear it click into place.
  10. Re install the ink cartridges. As needed, see Replacing ink cartridges.
  11. Close the printer access door. The printer should now complete a printhead calibration to ensure that it is ready to for normal operation.
Nov 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Ink
  1. Buy only genuine Dell replacement cartridges. Dell states their printer cartridges cannot be refilled with ink and that only their cartridges work in the printer.
  2. Bring the cartridge carrier of the printer to the center so you can access the ink cartridges. Open the cover of the printer and the carrier slides to the center. Make sure the printer is turned on.
  3. Remove the old black ink cartridge to use the color cartridge. If you allow the old black cartridge to remain in the printer, you will get error messages that the ink is low. The printer may also keep reverting back to the black ink as the default color when printing.
  4. Open the package of the new color cartridge carefully. Remove any blue packing tape that's on the ink cartridge. Take care not to touch the gold area or you could damage the cartridge. Insert the new color cartridge into the correct slot in the printer, the right side of the cartridge carrier. The ink cartridges aren't interchangeable; they need to be placed in the correct slot.
  5. Close the cover on your printer after installing the color cartridge. Run a print test to make sure the color cartridge is installed correctly. Use the Dell Ink Management System to monitor your printer and all-in-one functions. Thanks Thiru
Jun 15, 2009 | Dell 810 All-In-One InkJet Printer
The black ink cannot be
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed? Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred? Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If not, do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then there are other things we can try - assuming other solutions haven't worked either. Report back on my queries etc.
Feb 10, 2009 | Epson Stylus C43SX InkJet Printer
Dell printer model# A940 50c error
Test your cartridges.
Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Brother MFC-290C Printer Logo
52 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
