Question about Kitchen Ranges
Jenn-air range beeps and shows f7
Jenn-air model sce30600w serial number 21048159ym
  • 1314 Answers
SOURCE: jenn aire range model jjw9630aaw.
try pressing clock key
Posted on May 24, 2008
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
SOURCE: Jenn Air range model SVE47600 Beeping
range was beeping and showing code f4....would not stop unless i turned breaker off
Posted on Nov 12, 2009
SOURCE: replace digital display for Jenn-Air range
Obviously, safety first. This being an electrical fix, unplug or otherwise disconnect the power to the appliance.
A philips screwdriver and 1/4" nut driver(or socket) are all that's needed.
First, there are 8 fasteners on the underside of the control panel. Only the 4 nearest the oven openning need to be removed from here.
Next, remove the burner knobs for the stovetop(simply pull straight off; if stuck, wrap a folded wash cloth behind the knob to gain extra leverage). Then remove the 4 screws that were behind the knobs.
At this point the panel should be loose and pulling out the bottom of the control panel will allow it to clear the knob shafts. Be careful not to pull too far, as the wires to the control board are rather delicate.
Posted on Feb 27, 2010
woodchuck789
  • 4066 Answers
SOURCE: Error Code F7
F7 Function key shorted Replace touch padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
Posted on Mar 11, 2010
Oven beeps and displays F7. Hit stop/cancel, starts up again in about 10 seconds
Hi cpwdavis,
The F7 failure code shows a Function key shorted or stuck. To resolve this problem, you need to replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Sep 22, 2011 | Jenn-Air JES9800A Electric Kitchen Range
Was low temp roasting of ribs in Jenn Air JMW9530AAB convection oven. Heat webt ofand stove started to beep and displayed "-F7-". Cancel failed to do anything. Shut power off and when turned...
The electronic control may not be set correctly. If the control is not programmed correctly the oven will not start and you will usually hear a series of beeps instead of the microwave starting. See your Use & Care Guide
Aug 09, 2008 | Jenn-Air Kitchen Ranges
Top electric oven will show an F3 error after being turned on and will beep. Botton oven works fine. Jenn Air electric oven model JJW927AAW. Serial number 11993640WO
HI thanks for your question.. code F3 says to replace the oven sensor, located in the oven. top left corner. Replace the oven sensor. Thanks
Dec 17, 2010 | Jenn-Air Ovens
Model JES9750CAB: WHERE IS THE SERIAL NUMBER LOCATED
Hi
The serial number for Jenn air ranges are usually printed on a metal/paper label and would be present in one of the locactions--
Daniel
Aug 07, 2010 | Jenn-Air JES9860 Electric Kitchen Range
Jenn Air F7 error msg with incessant beeping
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
f7 is the code for a shorted keypad or membrane have your husband disconnect the mylar ribbion from the range and gently clean the end with a pencil eraser then reconnect and try again if that doesnt work replace the touch pad
Mar 11, 2008 | Kitchen Ranges
F7 Code and stove beeps
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back.  Unplug range before doing so.  Once touch pad is disconnected, plug range back in and see if code shows.  Wait a few minutes.  If no code then replace touch pad.  If code does come on while touch pad is disconnected then replace main control.  If touch pad and main control are all one part then replace the whole control.  Doubt if you would have any luck trying to unstick the bad button as stated above.
Oct 15, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
15 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
