Question about Copystar Office Equipment & Supplies
Printer cs 2050
When I try to make copies on the tray on top of the copier, it prints crooked. How can I fix this?
  • 214 Answers
SOURCE: paper feed and colour problems with Konica Minolta bizhub c250
any stripes are usually caused by imagining unit, first use the tool in front cover to clean laser glasses. inspect IU drums for stripes maybe youll need to change them. is the page coming out ok, but picture is printed crookedly ?
Posted on May 11, 2008
  • 7 Answers
SOURCE: kyocera cs 2050 copy has faded print down center
make sure the glass is clean it sounds like you either have a dirty scan glass or the wires need to be cleaned there should be a cleaner on the front cover of the macin that you you pull out and slide back abd fourth to clean it
Posted on May 05, 2009
SOURCE: printing crooked
As "Guest" posted on Feb 05, 2009 the problem for me was the box in the back of the printer that facilitates double sided printing. One side had come loose. I was getting "Paper Mismatch" errors, and the text was printing slanted. I simply pulled the box out and reinstalled it. Problem solved.
Posted on May 20, 2009
  • 4088 Answers
SOURCE: skewed or crooked paper uptake on Canon Pixma Mx300
Sounds like the roller(s) on the left side is missing or is slick (or split). You should have returned it to the place of purchase when you discovered the problem.
Posted on Jul 10, 2009
  • 21 Answers
SOURCE: 7760 DN printing crooked from tray 5
7760 dn solo tiene dos trays...
entiendo q la tray 5 sera el by-pass or left tray
la ultima vez q me paso eso es pq hicieron etiquetas q dejaron residuos de cola en el bafle de los rodillos de partida del by-pass, el papel se frenaba por el lado in y torcia el papel
Posted on Dec 02, 2009
Copystar CS-2050 cutting off edges when copying or scanning
Check your default paper size. It may have been set for A5.
Apr 07, 2014 | Copystar CS-2050 All-In-One Printer
Printing copies crooked
prints ok from a different tray????????????????????
Feb 14, 2014 | Konica Minolta Bizhub C224 Color Copier /...
I have a print mode error on my Kyocera Mita CS-2050 KX How do I reset the copier?
what the error code ?
if c6xxx you need to rest by program 163 just tell me the error code and i'll help you
thanks
Aug 10, 2010 | Copystar CS-2050 All-In-One Printer
Kyocera cs 2050 copy has faded print down center
May 05, 2009 | Kyocera CS-2050 Black and White Copier
Cannot setup/connect to Kyocera CS-2050
go to kyocera mita america online. they have all the drivers. you need the KX driver
Jan 21, 2009 | Kyocera CS-2050 Black and White Copier
Red and blue marks on copies
The CS 2050 is a mono color (black only) copier. There is nothing within this machine that I have EVER seen that has red and blue "ink" in it. I suggest you look at the paper that is in the tray itself. I have been on many service calls where the customer said the copier was tearing off a diagonal corner of the page, or the copier was putting something on the page that it was not capable of doing. When I looked at the paper in the tray I would find that the paper itself had the defect before it ever even went through the machine. Since there is 500 sheets per ****, and you may only see it on every 20th or 30th copy, you will have to either just try a new **** or go through whats in there 1 sheet at a time looking at both sides. But, if you find something that has blue and red ink within this machine please let me know.
Nov 24, 2008 | Copystar CS-2050 All-In-One Printer
Printing crooked from one drawer, and no option to print from another drawer
Try this spray on a little WD40 on the GLASS and wipe it off.
Yes, you heard me correctly, make sure you wipe it off leaving no residue, but it's still slippery.
the problem may be coming from the glass being too dry and the paper is getting stuckand shifting.
If the paper itself was going crooked it would get jammed or ripped. There is no room for the paper to go through the path crooked so the only way for it to copy crooked is somewhere in the optics.
try doing 1-2 on the glass itself and see if it copies crooked.
The envelope tray is a By-pass tray and can be used for any size paper.You can switch which tray it copies from on the panel tray button.
Aug 28, 2008 | Canon imageRUNNER 2200
Bypass tray
you have to set the paper size in bypass tray. do you have a manual? go to system menu/counter button and scroll down
Mar 25, 2008 | Kyocera CS-2050 Black and White Copier
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Scott Yeoman
Level 1 Expert
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
