Question about Bodum Coffee Makers & Espresso Machines
Bodum bistro won't turn on
Used it on e and now it won't turn on
2 Suggested Answers
SOURCE: Am considering buying a Bodum
It,s conical. It can be easely remowed for cleaning. Just take it easy so you know how to put the pieces back again. Its a very good priceworthy grinder. I still use mine after 15 years. But as it comes from the factory it will not grind fine enough for espresso. There are various methods and instructions on the internet how to tweak them to grind finer if you want that. Internally the mechanism looks very similar to the Solis and Dualit grinder. Since my grinder i quite old i dont know if my tweaks will work on more modern machines. But the basic construktion i still the same.
Posted on Feb 12, 2011
How can i get manual for model 10903?
Do you mean the Bodum Bistro electric coffee grinder 10903? The instructions for use are available on the product page: http://www.bodum.com/us/en-us/shop/detail/10903-01US/ . Look on the right hand side of the page. The direct link to the manual is http://www.bodum.com/media/ifu/10903-01US.pdf . See page 4-5 (7-8 of the PDF) for the directions for grinding. The cleaning directions are on page 6 (page 9 of the PDF).
I hope this helps.
May 11, 2016 | Coffee Makers & Espresso Machines
Water does not heat
PDF]Instructions for use (PDF) - Bodum
www.bodum.com/media/ifu/11001-01EURO.pdf
BodumCongratulations! You are the proud owner of a BISTRO pour over coffee machine fromBODUM®. Read through these instructions carefully before you use the
Aug 30, 2015 | Bodum Bistro Coffee Makers & Espresso...
How to fix a bodum bistro electric coffee grinder that doesn't grind well
This can be caused by several things;
If it used to be good but is now faulty it is most likely that it just needs cleaning. If you are using beans that are 'oily' they can clog the grinder, you should anyway disassemble it and clean every year. Do not use soap and water, just brush it with a stiff brush (e.g. the stiffest type of toothbrush) and a vacuum cleaner.
There is also a possibility that something has got into the grinder along with the coffee beans that has damaged the grinding wheels; in that case you need to replace the wheels.
Jul 29, 2014 | Bodum Bistro Electric Burr Grinder for...
Won't turn on :(
It sounds like you know nothing about elecrical stuff so safety first, take it to a repair shop. If you have no experience with this sort work you can easily kill yourself or burn your house down; poor electrical work causes many house fires, so take it to the repair shop
Ring the supplier it may be a common problem or an easy fix. If no luck there take it to a repairman, preferably at a Bodum Bistro repair shop.
If the switch is unavailable, they may be able remove it and see if another switch can be substituted or added.
The worst case would be short switch out and the grinder will be on all the time now and you can turn it on and off at the wall socket or fit an in line switch to the power cord.
Ask for an estimate as it may be cheaper or at least more practical to replace it.
If you try to do it yourself you may electrocute yourself or burn your house down, so do some overtime and use the money to pay for an expert repairer or a new one.
Feb 27, 2014 | Bodum Bistro Electric Burr Coffee Grinder...
My element has burnt out
I love my Bistro toaster but it will only heat on one side,
is it repairable?
Feb 10, 2014 | Bodum Bistro Toaster
Won turn fully charged battery
You sure your battery is fully charged and still good?
on the other hand Sony Cyber-shot's are known to have this problem.
Try pressing the on button for 5sec
Nov 24, 2017 | Sony Cyber-Shot DSC-WX9 Digital Camera
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
Myu Bodum Bistro burr grinder calibration is off. How do I fix it?
Did you ever find a solution? I have the same grinder and it is off as well now after taking it apart.
Nov 11, 2012 | Coffee Makers & Espresso Machines
My wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Dec 23, 2011 | Nintendo Wii Console
Coffee Makers & Espresso Machines Logo
171 people viewed this question
Top Bodum Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
ray gallant
Kolbrun...
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
