Question about Brother EM-530 Typewriter
Cartridge goes all the way to the left and keeps clicking then beeps and the oitch 10 and 12 flash
MX310 green light flashing and beeping. Won't turn off or reset
You can restart splooler....
--Right click on my computer
--click on manage (a new window open)
--to the left look for Services and application and double click
--this will drop down the some task.
--click on services
--then to your right look for the print splooler
--right click and click on restart.
Mar 04, 2013 | Canon PIXMA MX310 All-In-One Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    My ps3 it goes green beeps twice then goes red and flashes on/off
    you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
    Oct 14, 2009 | Sony Playstation 3 (PS3) Console
    My Canon s4500 not working, with 6 beeps error
    This is because the BJ Cartridge is not installed. Please refer to your manual page 214.
    Two beeps: Out of paper, or paper feed error
    Three beeps: Paper jam
    Four beeps: BJ Cartridge out of ink
    Five beeps: Cartridge not installed correctly
    Six beeps: BJ Cartridge not installed
    Seven beeps: BJ Cartridge defective
    Eight beeps: Waste ink tank almost full
    Nine beeps: Automatic print head alignment failed
    The POWER lamp flashes orange and green alternately with beeps: Service error
    YBC (/\)
    Oct 08, 2009 | Canon Office Equipment & Supplies
    BJC-8200 beeps 10 times and wont go online.
  • Hi
  • All The Best: Pineworks
  • Oct 06, 2009 | Canon BJC 8200 Photo InkJet Printer
    I have a hp office jet v 40 series fax, scanner, and copier
    Get rid of the HP 45, it is not compatable, even though it looks the same. Go buy the HP15 and the problem will be solved.
    Apr 14, 2009 | HP Office Equipment & Supplies
    Oven
    I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
    Aug 07, 2008 | Ovens
    Cannon BJC 80
    5 times try this:
    1: Unplug Power Cord
    2: Hold POWER and RESUME buttons
    3: Plug in Power Cord
    4: Release buttons after the printers starts up
    5: Hold CARTRIDGE and RESUME
    6: Press POWER
    7: Release all buttons after the beeps
    8: Press CARTRIDGE 16 times
    9: Press RESUME
    10: Unplug the Power cord
    3 times, probably something wrong with the cartridge.
    Nov 21, 2007 | Canon BJC 80 InkJet Printer
    Brother EM-530 Typewriter Logo
    48 people viewed this question
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Samyfam
    Samyfam
