Question about Sentry Fireproof Safe
Instructions for s23et
Where are buttons A AND B
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Reset lamp timer
Simple answer: -vol button on set and split button on remote hold at the same time
I just figured mine out!!!! So many people with so many different solutions. I read the instructions for the TV, those says to read the instructions for the lamp. I read the instructions for the lamp but this model isn't on the instruction list. For other models it says to use the volume down button on the set and the PIP on the remote. No PIP button on the remote. But wait the bottom row of buttons has a multifunction button for split screen! I tried that and it worked. I had a message that said the lamp timer was set to zero. Done! Hope this helps someone out there.
Feb 09, 2014 | Panasonic PT-61LCX65 61" Rear Projection...
Need the complete instructions
The instructions are hidden in the side of the cardboard box. You can download them from spynethq.com. Click on the blue flashing button on the middle of the screen. Click on the 'FAQ' button in the top right. Click on the watch icon. At the bottom left of the 'FAQ' box is a button to download instructions.
Dec 26, 2010 | Mission Spy Net Secret Mission Video Watch...
The yellow chronograph hand is set between the 11 and 12 instead on at the 12. The manual says to press a "Corrector" button (near number 8 on dial) however my watch does not have this button. How can I...
The instructions that you will find on their web site do not mention the button you describe.
Re-setting the hands is done by pressing the button B (4 o'clock). The instructions are a little ambiguous, so if this fails, then press button A to start and A again to Stop. Then try button B to re-set.
You appear to have the wrong instructions. A new set can be downloaded by going to their web site (www.raymond-weil.com), put your cursor over "customer care" and a drop down menu will appear. Select "instructions for use" and an index of watch types will be displayed. Download the one for your watch.
Jan 30, 2010 | Raymond Weil W1
I have the glow in the dark Sharper Image Jumbo Universal Remote Control. I bought it on clearance without instructions. I went to a site listed in FixYa to get the instructions. I got an Emerson...
Best to enter the remote brand and model # into the web (google) go from there . you can try retrevo.com good luck Julio Milleniumtcsvc@gmail.com
Jul 26, 2009 | Televison & Video
Unable to reset health o meter scale BFM676 need instruction man
I just got a BFM676 without instructions. I looked on Health O meter's home page. I then looked through various instruction manuals. One of them worked.
To adjust profiles. Turn on by pressing scroll. Choose profile number you want to edit with the scroll button. Hold down the Select button until the first height number starts flashing. Use the scroll button to change the numbers. Use the select button to change to the next field. Have fun. =)
Mar 09, 2009 | Health & Beauty
Need instructions for Timex 1440 Sport watch
just press the lap/reset button then press the mode button a letter A should appear
Oct 28, 2008 | Timex 1440 53591 Sports Quotient...
Ladies Armitron 45/6967
Armitron alarm/chrono
1.To set the time hold the mode button until the alarm flashes, then hit it one more time and the time will flash to be changed. Once the alram or time is flashing use the ST/STP button to navigate between hour, minute, month, day and day of the week, the ADJ button changes the numbers.
2.While holding down the ADJ button use the ST/STP button to turn off the hourly CHIME and the ALARM chime.
Hope this helps!! K~~
Sep 27, 2008 | JCPenney Armitron Sport Link Bracelet...
Columbia Watch CL-5030
Hold the light button (top left hand) for a few seconds and the adjustment mode becomes available.
Dec 25, 2007 | Columbia All Sport Digital watch
Sentry Fireproof Safe Logo
101 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
