Question about Bosch GST 135 BCE 220V Jig Saw
Bosch jigsaw Blade plunger not working up and down appears un attached
  • 12 Answers
SOURCE: Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Posted on Feb 25, 2009
  • 3 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
SOURCE: Changing the blade in a bosch pst 65 pae corded jigsaw
Pull up the knob on the front at the top of the machine and push the yellow bit forward. Theoretically you should turn the knob anticlockwise three turns but it doesn't seem to make any difference on my one. Then take hold of the blade, ease it forward and turn through 90 degrees. You should then be able to pull it out. Replacement is, as they say in all the best manuals, a simple reversal of the procedure. When you are turning the knob clockwise this time it's supposed to click in place but my one doesn't do this and still seems to work.
Best of luck
Gavin
shameerariff
  • 89 Answers
SOURCE: Replace the blade on jigsaw Bosch # 1587 AVS item # 0 061 587 683
YOu can download the user manual in the following links
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601587651&mn=1587AVS&init=1
The blade can be replaced by unscrewing the screw found on the shaft.
Posted on Jul 28, 2009
  • 548 Answers
SOURCE: bought a jigsaw a bosch pst 54e how do i change
In the handle directly over the blade is a deep hole. You insert a long thin bladed screw driver into this hole all the way down. Twist slowly and it will locate with a screw. Undo the screw and then twist the remaining piece of blade 90 deg and pull. Replace new blade in the opposite way. Twist it so that the cut is to the front and then tighten up the screw. Do not tip up the unit while doing this as the screw might drop out and you might loose it
Posted on Sep 24, 2009
Testimonial: "thanks.did the trick.use you again thanks"
Does any one out there know how to put a blade in a Bosch 1581VS jig saw?
video here
How to Replace a Bosch Jigsaw Blade - YouTube
? 1:30
https://www.youtube.com/watch?v=YzpExustLD0
Sep 8, 2011 - Uploaded by toolsandmachinery
Mike will show you the simplicity of changing a blade with the Bosch twist-lock Jigsaw
here is the manual for the 1584
Bosch 1584VS Manuals
Apr 19, 2017 | Bosch Saws
I have a bosch jigsaw and the blade keeps slipping out of the roller blade guide after it runs normal for a few seconds. ive reset the blade and changed it.
Hi Rebecca, I hope this helps;
BLADE INSTALLATION
Set the blade orbit selector lever to position III.
Push blade change button downward as far as
it will go and turn the top handle three turns
counterclockwise (viewed from the top of the
tool).
Insert the blade into blade plunger at a 90°
angle to the cutting direction. With a slight
upward pressure, turn the blade teeth forward
(direction of cut) and guide the back of the
blade into the groove in the center of blade
roller guide. Pull gently down on the blade to
seat the blade tabs in the plunger.
With the blade in the proper position, turn top
handle clockwise until a noticeable "Click" sound
is heard, indicating that the blade is locked in
place.
Push blade change button upward to its
original position (flush with the top of the top
handle), and the saw is ready for use.
Removing the blade is essentially the reverse
of the installation procedure, however, take
note that once the blade change button is
loosened, gently push the blade upward to
release the blade tabs from the plunger.
Feb 13, 2017 | Bosch Saws
Bosch b4300 jigsaw blade replacement
To change the Bosch B4300 blade - If the grey knob does not turn to release the broken blade, you need to use a LONG THIN flathead screwdriver down the center hole at the top. Unscrew until the broken blade is loose. Pull out. Replace the new blade and then screw the it tight through the same hole at the top. DONE.
Jan 25, 2012 | Bosch 1581AVSK Top Handle Jig Saw Kit
How the h... do i cabnge the blade on the bosch 1582 cutter ??
I am assuming you are asking because you have a CLIC system.
Bosch uses a tool-less blade changing system for its jigsaws that it calls "Clic." The system makes changing blades fast and simple. With the simple blade changing you get with the Bosch jigsaws, it is no problem to change out a dull blade.
REMEMBER: SAFETY FIRST LAST AND ALWAYS!!!
Make sure the saw is unplugged or the battery is removed.
If you have a blade in there:
Hold the saw over a work bench and push the ejector lever to the center of the front of the saw. There is a center stop; you will feel it. The blade will eject and fall out
Insert the new saw blade into the plunger until it latches into place. The teeth should face toward the front of the saw. The back of the blade should rest in the groove of the guide roller. The plunger and the guide roller are between the body of the saw and the plate
If the blade will not go into the plunger, check the positioning of the slots in the blade. They should be at the top. Push the ejector lever and try again.
Give the blade a yank to check that it is firmly seated. Plug the saw back in or replace the battery and proceed with the cut
Use protective gloves when handling blades. They can be sharp and can be HOT.
I hope this helps
Please rate FIXYA
Thanks
Charly
May 20, 2011 | Garden
My bosch jigsaw keeps saing sideways!!!
Most Bosch jigsaws have a handle on the top of the main handle that you need to pull up and rotate counterclockwise to allow the screw to accept the blade. Insert the blade and rotate 90 degrees into position then tighten the handle and press back down into place. In the beginning it may seem like you are going to break the handle pulling it up but rest assured it will get easier as it gets used.
May 10, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
Jul 28, 2009 | Bosch 1581AVSK Top Handle Jig Saw Kit
Blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
May 30, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Blade wont stay in Bosch 1882VS jig saw
ARE YOU USING BOSCH BLADES IF NOT GET SOME THEY ARE MADE A LITTLE DIFFERENT THAN SOME OF THE OTHER BRANDS AND FIT A LITTLE BETTER , IF YOU ARE THEN DO NOT KNOW
Feb 22, 2009 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
How to change blade on bosch jigsaw GST 80 PBE
I just bought a used one and faced the same problem. What I found in there is a set screw at the bottom of the long shaft. I used a long narrow flat head screw driver. It worked good, but I did have to acuate the trigger to get it the blade near the top of the stroke
Hope that helps.
AG
Porsgrunn Norway
Dec 07, 2007 | Coffee Makers & Espresso Machines
Bosch GST 135 BCE 220V Jig Saw Logo
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
