Question about Sirius Satellite Radio Receiver
Sirius stuck at Loading
Stuck at loading, factory installed in my 2010 kia soul have current subscription and have had refresh signal sent no luck.
5 Suggested Answers
MrScary66613
  • 1990 Answers
SOURCE: Acura TL XM conversion to Sirius
You can get a Windshield Mounting kit and Sirius Unit and use the FM Frequency Modualator that is Built in and just not use the XM.
Posted on Jan 01, 2009
bunnydawg
  • 5158 Answers
SOURCE: Starmate reciever (about 6 years old) shows
unhook the power to it for about ten to 15 minutes. hook the power back up and let it "boot" up. that should fix the issue
Posted on Aug 24, 2010
SOURCE: Why is my signal fading in out on my Sirius
I will advice you talk it to Sirius to help check the service antenna if it has broken, this is most likely the cause or better still if the Sirius star-mate st2 is still under warranty, you let them help replace it, because this is likely to be a panel problem if not service antenna problem.
Take care.
Posted on Sep 29, 2010
tss-radio
  • 62 Answers
SOURCE: my sirius is stuck on down loading, it still says 0 persent down loading .
Unfortunately some models of the Starmate Replay will not receive the latest updates. I have seen this with XTR8, which is essentially the same radio. If it is one of these outdated receivers, it will not receive the update, and there is not much you can do. You used to be able to let them sit for about 24 hours and it would eventually take. That does not appear to be the case anymore. This isn't the case with ALL of the ST2s if you wanted to hunt down a replacement. www.tss-radio.com can help
Posted on Jun 29, 2012
2010 kia soul if thermostat is not working what problems can it cause
Engine overheats if the thermostat is stuck in the closed position. Engine can be damaged permanently. Engine takes a long time to heat up if the thermostat is stuck in the open position. Defective thermostat in both situations.
Dec 16, 2013 | 2010 Kia Soul 2.0
No sirius id, no presets, all cleared... activation didn't help
You need to call sirius @ 1-888-GET-SIRIUS (438-7474) and they will remotly reset the radio for you. This has happened to me twice and this is the only way i have found to fix it.
Oct 30, 2008 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Inertia switch location on a 2010 kia soul
Fuel Safety Shut Off Switch
Only on Ford Products
Dec 18, 2012 | 2010 Kia Soul 2.0
Why do i only get 184 and no other stations
You need to put the van out in the open with the radio "ON" (car off) and leave it on CH184. Call the 800 (855-whatever) number and ask them to send a "refresh signal" to your radio after you give them the Serial number from channel 0. Wait about 20 minutes, you should eventually see an "updating" message on the display; then see if you get channel 5; if so, then you're good. Again. Car off; radio power on, van out in the open; call Sirius and ask for a 'refresh signal' for your serial number. You'll have to call during the day when they have customer service reps available. Good luck; call on your cellphone and they can walk you thru these same steps.
Dec 02, 2012 | Sirius Satellite Radio Receiver
My 2008 ford focus sirius radio stopped working. sirius tried to reprogram, but it didn't work
Did Sirius resend a signal? If it is displaying their number it is likely that your subscription needs to be updated. The fact that it displays their info means it is likely receiving a signal. If it said "no tuner" or nothing at all, it would likely be the tuner. You can resend a signal online here:
http://www.siriusxm.com/activationhelp
If that does not work, replacement kits are available here:
http://www.tss-radio.com/products/isimple-factory-ipod-and-sirius-integration-for-ford-lincoln-mercury-vehicles-1
Jun 24, 2012 | 2008 Ford Focus SE Sedan
2010 Kia soul car alarm won't stop blinking.
I think one of your door latches was not closed all the way. Check that first.
Aug 03, 2011 | 2010 Kia Soul
My Sirius radio, factory installed in a 2008 VW R32, won't activate, even after a "soft boot". Sirius mentioned having the dealer do a "hard boot". What is that?
I hope this post finds everyone well who is having difficulties with Sirius Radio's trouble shooting advice to reactivate service. I tried to reactivated my service and had experienced all the problems that everyone has had on these forums. This is what works. It took me a lot of phone calls and I want to get the word out to everyone (regardless of Make, Model or Year of Vehicle)
First, a soft reboot does nothing and there is no such things as 'reseting' the electric system in your car. Second, there is no such thing as a 'hard' reboot to your sirius radio. All a soft reboot will get you is cold legs when you have to hold your car door open for 30 seconds in the middle of winter. All a hard reboot will do is cost you a lot of hard earned money at the dealership. Best case scenario is that your dealer replaces your entire radio and charges you $500+.
WHAT YOU NEED TO DO: Call Sirius Customer Service and ask for Technical Support. Explain to them you are having difficulty obtaining an activation signal. The technical support technician did the following (and it was the most intelligent thing I heard from Sirius)
1. Go turn on your Sirius Radio and tune to Channel 184.
2. The technician put a "dummy" ESN in on my account, refreshed and then re-entered my original ESN back into my account and then re-sent the activation signal. **NOTE** Make sure you write down your original ESN number before you ask to have them do step #2....there is no way for them to recover your original ESN if they put in the 'dummy' ESN and refresh.
3. Within 10 seconds of putting doing step #2, my Sirius Radio said, "Updating Channels" and worked great.
Takeaway from My Experience: I believe that once you let your Sirius Radio Service relapse and/or do not renew your subscription, a signal/frequency is sent to your radio to block service or reactivate your service. The problem must be an internal issue on Sirius where the only fix to stop this signal is to completely clear (or zero) out your original ESN, enter a dummy ESN, refresh and then re-enter your original ESN and then send the activation signal.
I hope this helps everyone.
Sep 02, 2010 | Sirius Satellite Radio Receiver
Satellite radio (REF) not connecting with Sirius.
Do you have a paid subscription? IF you do, call and have them with your radio's serial number and ask them to 'refresh' your radio to restore the other channels. If you only have channel 184 and CH1, it sounds like you haven't purchased a monthly subscription yet.
Dec 21, 2009 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Pioneer AVIC 700 sirius satellite radio stopped working, stuck on
My AVIC-F900BT was stuck on one channel and wouldn't change. There was no sound. Radio head detected Satelitte system, but no buttons worked. Found on the internet a solution that worked for me. I disconnnect the battery terminals for 5 minutes and then connected them. When the system rebooted, the Sirius radio worked fine. I'm posting this hopeing it will help someone.
Oct 03, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Sirius Satellite Radio Receiver Logo
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
