Question about Casio Parts Cash Register PC Desktop
Slip printer how to let them work together
  • Casio Master
  • 1,654 Answers
There are many settings on register that need to be configured in order to use a slip printer properly. Check the programming manual for these. If you need a manual, try C-tech:
http://the-checkout-tech.com/
Posted on Feb 17, 2014
What does ssk mean in knitting and do you have a list of different meanings for kniting
Slip slip knit or SSK is a basic way to decrease stitches. It makes a decrease that slants to the left and is often paired with knit two together, which is a right-slanting decrease.
To execute this decrease, slip the first stitch as if to knit, slip the second stitch as if to knit, then slide the left-hand needle into the front part of both stitches and knit them together.
Oct 21, 2014 | Sewing Machines
Replacement patch cable for Epson kitchen printer to Micros e7
As long as the ends (connections) of the cable are in good condition and only the cable was cut; I would solder the wires to the corresponding colored wires to one another and insulate the soldered joints to prevent them from shorting out. If you have what is called Shrink tubing (From Radio Shack) slip a small piece over the wire prior to soldering the two ends. After the two wires are joined; slip the wrap over the joint and heat with a hot iron or hair dryer. The wrap shrinks around the soldered joint and insulates it from the other wires. Do that for all wires to be joined together. When done the bundle if wires may be bulky, but they will get the job done. Lastly surround the wires with electrical tape to keep them all together.
Dec 18, 2013 | Epson TM-U220 Matrix Printer
Casio qt 2100 programming I/O for epson tm-t88III
I haven't worked on the 2100 for years but I know you can't use a TMT88 series as a slip printer. The TMT88 is for receipts or kitchen. If you want to print special slips, you would need to get a dot matrix slip printer. This model is compatible with the SA-3015 and SP-1300 Slip printers.
Feb 21, 2013 | Casio Parts Cash Register PC Desktop
Maytag washer lat9416aaq belt slips in spin cycle put new belt on and springs
The motor is supossed to walk up the belt to let it slip enough so the pump can run and drain out the water before the drum spins at full speed( that's why it's spring mounted).
Check the pump belt, it should be snug but not tight, you should have some give when you squeeze the belt together, but it should not touch together. Don't use any belt dressing on it, it needs to slip. Make sure the washer is unpluged before you do anything.
Feb 05, 2010 | Maytag Washing Machines
Does the breadman tr845 use a belt to turn the dough mechanism? if so where can i buy one?
Yes, the Breadman TR845 uses a belt to connect the knead paddle to the motor. I had a problem with my Breadman so I took it apart. It turned out for me that the belt was fine but it had slipped off the plastic gear. The belt was still around the shaft of the motor so it could only turn if the bread pan was empty. The belt is a timing belt with integral teeth. I needed a small space washer that would keep the black plastic gear from slipping on the shaft and allowing the belt to slip off the gear. There is a lip only on one side of the plastic gear so if it moves the belt can slip off. I created a spacer washer from the cap on a tube of toothpaste. I cut the cap in half and had to use a metal file to get it the right size. I needed it to be 1/4 tall and 3/4 inch in diameter. I cut the spacer so that I could slip it over the shaft of the motor. The spacer keeps the black plastic gear from sliding and it keeps the belt from slipping off the gear. After putting it all back together everything works fine. And the toothpaste tube was almost empty anyway.
P.S. There are losts of screws that hold it together and the belt and gears are at the bottom of the Breadman and you have to take the whole thing apart to get to the bottom. I was able to leave all the wires attached so that putting it back together went quickly compared to the work of taking it apart.
Jan 17, 2010 | Breadman TR845 Bread Maker
Gear grinding noise when scanner wont work
Unfortunately the problem can only be solved by replacing the plastic gear that is turned by the metal motor gear. The gear becomes loose on the axle and that allows enough movement for the motor metal gear to slip over it. If parts can be found, it is an easy fix but where can those parts be found
Apr 19, 2009 | Office Equipment & Supplies
Hi! i need assistance on the Hero TH82 serial slip printer, particularly the drivers. I have some Epson Slip printer drivers but i'm npt sure if they are compatible
Thank you, i have found a solution. I have installed the generic text only printer, then i installed the Epson TMU 220D printer & drivers and it worked perfectly. Remember that your printer (Hero TH82) is simply to open the till drawer. The generic printer is the one that raelly works. Hope that i have been of help.
Jan 24, 2009 | Office Equipment & Supplies
Paper will not feed through though the carts do pass
My printer did the same thing, paper would not feed through so my son and i took it all apart and found the feed driver gear to be cracked, "it's a little plastic gear on a long shaft", and it was slipping on the shaft.
To fix it we hard wired the gear together where it was cracked to made it more tight on the shaft.
Unfortunatly by taking it all apart we broke it, now it gives an error message "Carrier stall press power key", havent't found a fix for that yet, but we will :)
Jul 20, 2008 | Lexmark X83 All-In-One InkJet Printer
How to replace back cover of MFC-210C?
There are two clips on either side which need to be squeezed together then the cover can be slipped back into position.
Apr 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Casio Parts Cash Register PC Desktop Logo
29 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
