Question about Hannspree 28" Widescreen Flat-Panel LCD HD Monitor
REMOTE CODE and ONLY GET 1 CHANNEL
Purchased used. No Hannspree remote - Only have universal remote. Manual turn on to one channel. channel button doesn't change to other channels?
Hanspree don't really have a manufacturer code for universal remote,
but you can use "1004" or other one of the vizio codes, that works for me.
Posted on Oct 05, 2014
4 Suggested Answers
  • 1768 Answers
SOURCE: What is the remote control tv code for a Hannspree
if you go to this online site you should be able to find your codes.
http://www.hannspree.com/us/common.aspx?mid=6172
Posted on May 15, 2010
jyackle5
  • 8197 Answers
SOURCE: I need a comcast remote
May You please tell me what remote you have on the link below.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Thank you
Posted on Nov 09, 2010
  • 17 Answers
SOURCE: I am trying to find a remote code for the Cox 7820
I have a Hannspree 42" LCD and I have the exact same problem, the code worked to control all functions except "Power On". I checked the Hannspree web site's support section, it says that their TVs will not work with a universal remote unless you have DirecTV. So why does everything work except to turn it on if they claim their TVs do not work with other remotes?
Posted on Dec 10, 2010
No remote or code. only get one channel with manual turn on.
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes.There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices.After confirming this, check the sites linked here.Both the sites have set-up code list and set-up procedure to many popular brand remote controls.Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability?Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual.Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Feb 13, 2014 | Hannspree XV32 32 in. LCD Television
Philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Jul 29, 2008 | Philips Televison & Video
I lost my remote codes
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
Universal Remote control code on Sharp 13H-M60
Hope this helps :)
Jun 19, 2008 | Televison & Video
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Programing
Hope this helps :)
Jun 09, 2008 | Philips Universal PH301S Remote Control
Remote codes for philips universal
Hope this helps :)
May 14, 2008 | Philips Universal PH301S Remote Control
Remotes codes
Hope this helps :)
May 11, 2008 | Philips Universal PH301S Remote Control
Remote code
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
Remote control
I was able to get my Motorola DVR Cable Box to work with my Universal Remote using the following instructions:
The Instruction Manual for Manual Code Search seems incorrect. (Page 5).
A) Manually turn on the device to be controlled. (O.K.)
B) Press and hold the code search button until the red indicator stays on, then release the code search button. (O.K.)
C) Press and quickly release the desired mode button (TV, VCR). The red indicator blinks off once. (O.K.)
D) Face the remote control directly to the device you want to control. (O.K.)
E.) Press the ON/OFF Button (this should read CHANNEL UP button) repeatedly until the device to be controlled changes channel. The red button blinks off with each button press.
F) Press and release enter to install the code. (O.K.)
-Note, the remote is able to change the channel, however, it does not control the volume.
Jan 03, 2008 | Televison & Video
Hannspree 28" Widescreen Flat-Panel LCD HD Monitor Logo
114 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
