Question about Roxio Easy VHS to DVD 3 Plus PC
Recording time Why can I not set recording time to more than 60 minutes
How long recording time with a dv tape in canon zr70mc
That obviously depends on the length of the tape. With an 80 minute tape, you can record for 80 minutes in SP mode or 120 minutes in LP mode. With a 60 minute tape, the numbers are 60 minutes and 90 minutes.
Sep 11, 2013 | Canon ZR70MC Mini DV Digital Camcorder
Why does my camera stop recording after one hour? i need to record 90 minutes
Your camera records in two modes: SP and LP modes. SP is a higher quality mode that runs for about 60 minutes, while LP records for 90.
To change to LP mode, open the menu and select [VCR setup]. Select [REC MODE], set it to [LP] and close the menu.
Keep in mind that your video and audio will be of noticeably lower quality with this setting applied.
Mar 08, 2011 | Canon ZR200 Mini DV Digital Camcorder
What are the differences in the record modes? (HQ, SP, & LP)
The amount of recording time on a disc depends on the recording mode selected. The approximate recording time for each of these modes is listed below:
  • HQ (High Quality): Recordable time is up to 20 minutes.
  • SP (Standard Play): Recordable time is up to 30 minutes.
  • LP (Long Play): Recordable time is up to 60 minutes.
  • NOTE: If you record in LP mode, the quality of the scenes may be degraded, or scenes with quick movement may appear with a block noise when you play back the disc.
    Jul 08, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
    Limited recording time
    WS-100: 64 MB
    HQ mode: Approx. 4 hours 20 minutes
    SP mode: Approx. 8 hours 40 minutes
    LP mode: Approx. 27 hours 20 minutes
    You can go to the menu of the device and change the recording mode from HQ to SP to get longer recording time. Page 7 of the instructions explains how to change this.
    Mar 19, 2009 | Olympus WS-100 Digital Voice Recorder
    Timing of Mastering and burning final copy to CD
    I don't use my Tascam to create CDs for exactly the reasons you are asking about. I do a bounce mix to a couple of tracks and then export via usb to a PC for finalizing and CD creation there.
    To answer your questions, you do always need to create a master first for each sermon on the DP-02 before you can burn it to a CD. You also have to finalize the CD to play it on other players.
    Mastering as well occurs in real time, so it does take 60 minutes to create a master for a 60 minute recording.
    As I don't burn from my Tascam, I didn't realize the burn time was so long though. I would have expected that to be faster for sure. I know my old 2488 MkI is supposed to burn at 4x and I believe the MkII burns at 8x. The DP-02 is newer than both and I would assume it would burn even faster.
    Anyway, as I said you might wish to go the PC route. That way you can export the tracks without having to master them and burn them from the PC to CD at up to 40x (depending on the speed of your PC's burner).
    Hope this helps.
    bd.
    Jan 06, 2009 | Tascam DP01 All-In-One Recording Package...
    Can the Panasonic AG-DV2500 play 90 minutes Minidv tapes?
    the DV2500 will not play LP (90 minute) tapes. when an LP tape is inserted, it will play for 2-3 seconds, and then eject.
    Nov 28, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
    Zenith XBR617 DVD Sometimes doesn't record full time scheduled
    sounds like your clock is wackie. SEE if there is a back up [computer type button] battery in a small draw just by the clock or see your manual for directions on where it is. Replace the battery.Do you have interupted electircity in your [brown outs] area ? That shuts down the recording timer and resets it. Your clock is the 1st thing I would check, 2nd is the electricity.
    Nov 12, 2008 | Televison & Video
    Recording more than one VHS onto a DVD
    Try pausing the dvd recorder inbetween tapes, this usually works, otherwise consult your owners manual
    Jan 09, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
    What are the approximate recording times of the filming
    Extra Fine (available on DVD-RAM discs) -- 20-60 minutes/side Fine (available on DVD-R and DVD-RAM discs) -- 30 minutes/side Standard (available on DVD-R and DVD-RAM discs) -- 60 minutes/side
    Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
    Roxio Easy VHS to DVD 3 Plus PC Logo
    18 people viewed this question
    Top Roxio Video Cameras Experts
    Are you a Roxio Video Camera Expert? Answer questions, earn points and help others
