Question about AZiO KB338BP Keyboard Wireless Bluetooth Multimedia Keyboard P/N: Kb33
Azio keyboard keys are sticking - AZiO KB338BP Keyboard Wireless Bluetooth Multimedia Keyboard P/N: Kb33
Tip
Repair ACER Keyboard
Many a times, laptop's keys fell off the keyboard or it gets damaged. Don't fret on buying a whole new keyboard when you can repair the keys yourself.
This is an installation guide to repair keys of Acer’s laptop keyboard.
You should have a key cap and 2 or more retainer clips (plastic pieces), that goes underneath the key cap.
To install the key on your laptop keyboard, start out by observing the metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard. The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the bottom and two metal hooks at the top.
Take the larger plastic piece and observe that it has two holes at the top corners, two sticks at the bottom and two holes in the middle. The top holes are going to go into the top metal hooks on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Take the smaller plastic piece and observe that it has two holes at the top, two sticks at the middle and a bar with larger hole at the bottom. The sticks in the middle are going to go into the middle holes of the larger plastic piece. The bottom bar is going to click onto the bottom metal hook on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Place the smaller plastic piece onto the larger plastic piece and insert its sticks to the holes of larger piece. It’s one piece now.
Insert the top plastic sticks into the top metal holes and the bottom bar into the bottom metal hook on the keyboard. Get a thin object or a blade and stretch the plastic pieces downwards to insert completely.
Take your letter key cap, put it in the middle of the plastic pieces and push down evenly from all four sides.
That's all to repair ACER keyboard key.
Source: Acer Key Repair
on Dec 17, 2009 | Computers & Internet
Tip
Replace DELL Laptop Keyboard Key
Sometimes with Dell laptops, the keys on the keyboard gets stuck or damaged or fells off the keyboard. There are many different ways to repair your broken keys. Just put your mind to it and you will be able to repair it yourself.
You can place an order to replace your broken key or you can repair it you have all the parts intact.
You should have a key cap, 2 or more retainer clips (plastic pieces), which goes under the key cap.
Following is the installation guide to replace and repair Dell laptop key.
To install your key on your laptop keyboard, start out by observing your metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard.The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the top and two metal hooks at the bottom.
Take the larger plastic piece and observe that it has two larger sticks at the bottom, two holes at the middle and two shorter sticks at the top. The bottom sticks are going to go into the bottom metal hooks. The smooth part faces away from the keyboard.
Take the smaller plastic piece and observe that it has a small bar at the bottom, two sticks at the top and two sticks at the middle. The sticks in the middle are going to go into the middle holes of the larger piece and the bar is going to click on to the top metal hook. The smooth part faces away from the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece.
Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces upwards so that it clicks together.
Take your letter key, put it in the middle and push down evenly from all four sides.
You’ve just repaired your Dell laptop keyboard.
Source: LaptopKey
on Dec 16, 2009 | Computers & Internet
When typing on keys it put multiple letters
The keys are sticking. Has something been spilled on it? Try these things:
Compressed air under the keys.
A blunt thin knife to jiggle keys slightly, be careful.
A damp cloth.
Feb 16, 2014 | Kensington KeyFolio Pro 2 Universal...
Laser no longer working
I have a feeling that the wire has a break in it it should be an easy fix Check for continuity with a multimeter.
Nov 28, 2013 | AZiO Levetron Laser Gaming Mouse GM-2000 /...
While I am typing keys will stick like lllllllllllllllllllllll all across the page until finally it stops. How do I fix this?
blow out the keyboard and keys, with 'compressed air' cleaner~should solve problem
if not, then may have to remove individual key sticking and clean with q-tip n alcohol
be careful when removing keys, make sure to disconnect from computor first and remove battery if necessary~this way it wont connect to computor when replacing keys
Jan 13, 2011 | Dell Bluetooth Wireless Keyboard/Mouse for...
Keys sticking
I don't know which keys are sticking, but if they do stick, it usually means it's time for a new keyboard. Desktop keyboards are relatively easy to clean. No so with laptops.
I'd be looking for a new keyboard. Try E-bay first for the best price.
Nov 03, 2010 | Acer Aspire 5735 Notebook
Keys stick on the keyboard T D V F IN particular.
If you use a laptop then the keys should be able to come off. You probably have something stuck underneath the keys. Get a small screwdriver and slowly prise the key off. give the key a good wipe underneath the key and on the connetion.
Mar 19, 2010 | Dell 0Y3740 Keyboard
Backspace Key is sticking on keyboard
hi,I can help you.all you need to do is.pop the key off apply a little rubbing alcohol to the key and joint where it goes.be sure not to use to much as it will seep into keyboard.
Mar 06, 2009 | Computers & Internet
AZiO KB338BP Keyboard Wireless Bluetooth Multimedia Keyboard P/N: Kb33 Logo
Top AZiO Computers & Internet Experts
David Payne
David Payne
Are you an AZiO Computer and Internet Expert? Answer questions, earn points and help others
