Question about Xerox WorkCentre 7556/P Copier
Avery business cards won't print vis bYpass tray
3 Suggested Answers
johnychel
  • 796 Answers
SOURCE: Tray 5 Diabled
see this link for help
http://www.fixya.com/support/t319195-print_qualityfor_dc12
Posted on Mar 02, 2008
  • 2072 Answers
SOURCE: i can't seem to print avery business cards from
Sounds like the maching rollers are just dirty and slipping on that paper.
I would open the paper path, and look for all the gray rollers. Use a 2 step process to clean them. First use something like Fantastic, or formula 409, a stronger soapy cleaner to clean all those rollers, then clean them a second time with rubbing alchol.
One will clean off paper dust, general dirt the other will break down ink and oils that may also be on the rollers. You may want to clean them 2 or 3 times if it has never been done.
Posted on Jan 06, 2010
How do I print cardstock with Samsung ML-2510?
Hi
I found a manual for your printer here:
http://downloadcenter.samsung.com/content/MM/200605/20060510151657234/um_ml-2570_manual_eng_060328.pdf
and under print media, it suggests limits of 60 to 163 g/m2 for the 2 trays. If you get some 160 g/sm2 card which is quite readily available, I think you will find it much lighter than the Avery business cards card, which from memory come in around the 200 - 220 g/sm2 level.
Even Avery quote this card as "heavyweight card stock", and although the say will print on all laser printers, it's my experience that they do not. Only on a laser with a flat paper path.
Cheers
Mar 02, 2015 | Avery 5376 Perforated Business Card
How can I get my Avery 8876 business card sheets to feed through my printer?
Avery is a fairly good name in the business.Brother on the other hand seems to have ignored the reasons why folks don't buy brothers. It's these little annoying things that bigger company's have spent time and energy on. For one there's usually a lever you push to control how much pressure the two fusing rollers push; hot rollers, for years this perplexed the big guys because there all ready is a pretty small tolerance of melting the toner and not burning the paper; melting the toner(powered plastic) next was the ever annoying OHP overhead projector sheets. this is plastic toner on plastic"paper" nightmare! melt the toner but not the plastic its on.... Well enough of engineering issues, time and perseverance paid off. now comes a sticky label on a waxxy surface that is twice as thick as paper and yet has toner to be fixed on it and dried....Some company's like cannon tried a cold roller that seemed to work at first but when things went bad they really went bad.labels coming off all in the wrong places... Toshiba and Savin Ricoh decided to get with Avery and others and make one side harder to come off than the other; reduce the squeeze pressure and increase the opposite "static cling" voltage. Also the angle it hit the feed section// Bypass feed only/Lt-R. Following the printed directions in the individual label sheet seemed to reduce the issue to a minimum. Understanding all the changes the poor piece has to go go through in an 8second processes is half the battle. hope this helps a smidge~~~SC
Nov 08, 2014 | Office Equipment & Supplies
My HP Deskjt F4280 will not print Avery injet 08371 business cards. I tryed the other number on the cards, 5371. Neither of them will line up proper. If I print on a blank paper it is printed correct. ...
you realy cannot print with that paper the ink cannot penetrate through, i have an experience here before and tried it on epson it print perfectly
Aug 07, 2011 | Office Equipment & Supplies
Hi I am trying to print labels. Avery #05161 and business cards Avery8371TM or 5371TM. I am using Microsoft Office and there do not seem to be any relevant numbers. I have gone under labels. Help Thanks
You can use a different template for either the labels or the business cards, just make sure the labels you choose are the same size as the avery 05161 & the business cards are the same paper eg: glossy etc. The other thing you can do is go to avery.com & download the correct templates.
I hope this helps you
Jan 21, 2011 | Avery Address Labels AVE4151
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
Printing Business Cards
My problem with alignment was caused by the printer being set to the wrong paper size (A4 not letter). This may not be a solution to the first problem.
Apr 21, 2009 | Office Equipment & Supplies
Printing on business card stock
goto avery website and download designpro for free it has all the templates for avery stationary
Mar 18, 2009 | Lexmark X6570 InkJet Printer
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    I am printing business cards and I am using thick paper but colors come out dull looking but if I change the paper to PLAIN then the colors come out just perfect, full, vivid and rich but I am afraid that...
    Its most likely the paper you are printing on. It sounds like this is an ink printer. The way ink works is that it is absorbed into the paper you are printing on. Some paper pulls the ink too far into the paper causing it to look dull and faded. You need to make sure you are printing on paper that is designed for inkjet printers. There are a lot of companies that make special paper designed for printing your own business cards. I prefer Avery products since they have a guarantee.
    Check this link out for some options on InkJet business card options.
    http://www.avery.com/avery/en_us/Products/Cards/Business-Cards/_/Ns=Rank%7C1%7C%7CProduct%20Number%7C1
    I hope this is solves your issue....Violet
    Jan 23, 2009 | Office Equipment & Supplies
    Repeated paper jam in fuser
    Fuser's orange roller is not meant to be wrinkled, if this is then I would recommend you replace it (just slides out) pic below
    b4eead5.jpg If printing on card, you need to feed via manual bypass and exit from the back, not on the top, aka the "face up tray." Tray pulls out from rear. Rear tray will only stack a few card sheets at once.
    Setting on printer's control panel must be set to card/heavy paper type on manual bypass tray
    Their may still be some card in fuser causing jams.
    Please rate as FIxya or post back,
    Cheers
    S. :-)
    Jan 01, 2008 | OKI C5200n Laser Printer
    Xerox WorkCentre 7556/P Copier Logo
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
