Question about Toshiba CT-847 Remote Control
Can not get tv on correct input - Toshiba CT-847 Remote Control
Blue ray player nothing happens when I turn it on
Do you have it connected to the correct input on your TV and have that input selected in the "Source" control of the TV? If you're using HDMI cables, be sure they're connected to the correct input on the TV (some have multiple inputs) and you have selected the one you connected to.
Nov 29, 2014 | Panasonic Televison & Video
No signal on tv screen
Is it registering the correct input? HDMI/ AV1/ AV2/ SCART!
Nov 05, 2014 | Televison & Video
Why Soyo tv says no signal?
Means TV is not connected or not getting input signal from antenna, cable, DVD etc..
Make the TV is on the correct input/source.
Jul 25, 2014 | Televison & Video
How do u put tv on hd input
If this model has that it will be one of the rear sets of component jacks which will be marked as HD or 1080-----use the input button on the remote or the set if there to change to the correct input on the set. Hookup and select correct input.
Dec 03, 2012 | JVC AV-32S575 32" TV
INSTALL DVD PLAYER TO MY TV AND ITURN ON THE DVD TO PLAY AND DID NOT COME ON
Try double checking your connection on both ends (from the dvd player and to your tv). Be sure the colors of the cable (e.g. red, white, yellow) are inserted in the correct place (according to color) on both the dvd player and the tv. Also check to make sure when you turn your dvd player on and the tv on that your tv is on the correct input. The tv usually shows which input is being used where the cables are connected (e.g. audio/video 1, hdmi 1, etc). If the tv does not specify the different inputs where the cables are inserted, use the tv remote to go through the different inputs by pressing the input button until you have either selected the correct one or gone through all of the available inputs. Be sure to allow enough time (10-15 seconds) for each input to register any kind of signal, and also be sure that the dvd player is on before searching through the inputs.
Feb 28, 2011 | Onkyo DV-SP302 Progressive Scan DVD Player
It lights up but no response to TV. Cannot program. HDMI connected
Have you selected the correct HDMI input on the TV-
press the input button on your TV or the TV remote to select the correct "input".
Good luck !
Feb 02, 2010 | Televison & Video
Lost the direct TV signal to the TV when nephew pushed a button on the remote (he doesn't remember which button) The other TVs in the house receive signals per usual.
Your nephew must have pushed the "Input" button on the remote. The TV is now looking for signal at a different input.
On the remote, press the input button until the TV switches back to the correct input. Make sure the satellite receiver is turned on so when the TV lands on the correct input, you will know it.
Dec 17, 2009 | Cars & Trucks
Tv works jsut no pic black and white screen says weak or no signel?
If it says "weak or no signal", this means your are not showing the correct input or have no channels programmed.
To find the the correct video input:
1. turn On the device you are trying to see
2. press the [input] button on the side of the TV until you get a picture (wait 3 seconds between pressing the button)
You program the TV by accessing it in the User Menu.
Also, You may access the inputs using the TV remote. Each input button (V4 and V5) may need to be pressed muliptle time to access the picture . When you press this on the remote you will notice the input change from Composite 1, Component 1, S-Video. V5 will show composite 2 and component 2. Using the side panel allows youto scan all inputs in case you are not sure.
Jun 23, 2009 | JVC LT42P789 42 in. LCD TV
Sony trinitron xbr 32"
Did you correctly select the S-Video input on the TV via the remote? In other words, if the TV is not set to look at the S-Video input then nothing will happen. You have either an "input", "source" or tv/vcr button that will allow you to select what input the tv will look at for a signal. Make sure it's set to S-Video.
Nov 13, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Dvdirect signal missing
In my case...DVDirect may have been detecting some sort of copyguard (copy protection) ....not sure.
Sep 04, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
Toshiba CT-847 Remote Control Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
