Question about Bunn BT10B Coffee Maker
Bunn thermal fuse - Bunn BT10B Coffee Maker
I changed my thermal fuse on my Bunn grx-b because it was not heating the water. Now it's like it is overheating. What could it be
hope this is of some help
the thermal fuse is blowing because the unit is getting to hot you replacing the thermal fuse has not cured the problem, and it will blow again , the problem is the thermostat is set to high or is faulty / allowing the unit to go over temperature hence the thermal fuse blowing
its the control stat that you should be looking at. good luck
Nov 19, 2016 | Bunn Coffee Makers & Espresso Machines
How to fix a Bunn NHBX that produces warm, not hot, coffee?
Thermal fuse is blown. Above and almost behind tank, and most likely brown. New one at www.bunn.com
Mar 02, 2015 | Bunn NHBX-B Contemporary 10-Cup Home...
How do I fix my coffee maker
most of tank heater of BUNN have some thermal fuse connected along thhe line before the heater terminal .that fuse might be open or worse ur heater spoiled already
Aug 31, 2014 | Bunn 10 Cup Home Coffee Brewer
Had a power outage and now the warmer light doesnt come on and the water is cold. checked outlet and it is working.
This is most likely the thermal fuses on the heating elements. They are not difficult to replace but do a continuity check before the thermal fuse and the element terminal on each of the wires. You should be able get fuses from your local bunn distributor.
Mar 12, 2014 | Bunn NHB Coffee Maker
Water is not hot when turn on
check the heat switch in the rear. if it's on, check the thermal fuse in the top right rear of the brewer. it'll be in a now browned tubing. you can get it through bunn (800) 352-BUNN (2866)
Jan 05, 2014 | Bunn CWTF 15-APS Coffee Maker
Water not coming out of hot water spigot
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Dec 10, 2013 | Bunn CWTF 15-APS Coffee Maker
Bunn coffee maker heating element wont turn off
Apr 13, 2013 | Bunn CWTF 15-3 Coffee Maker
Bunn coffee maker, no hot water
Mar 16, 2013 | Bunn CWTF35
I have cwtf15-aps older model. Device is wired and plummbed in. lights are working but i get no hot water. Has not been used for about 3 years.
Dec 12, 2010 | Bunn CWTF15-TC
Bunn BT10B Coffee Maker Logo
67 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
