Question about HP PSC 1209 All-in-One InkJet Printer
How can I get rid of lines on photos - HP PSC 1209 All-in-One InkJet Printer
  • HP Master
  • 783 Answers
Sir/Madam
Step one: Retry the print
If printing on glossy paper was paused or interrupted in the middle of the print job (for instance, if a cartridge was replaced), the resulting print may show a grainy band. In this case, retry the print and avoid interrupting the job.
Step two: Free up system resources and ensure direct communication
The PC can cause the printer to pause if it is not fast enough to keep the printer fed with data. The following steps can help alleviate this problem.
  1. Make sure that the PC meets the minimum system requirements for this printer.
  2. Restart the PC.
  3. Close out of all programs except for the program the print out will originate from.
  4. Shut down programs running in the Task Bar by right clicking on them and choosing exit. These programs will restart the next time the PC is rebooted.
  5. Ensure that the USB cable is 10 feet in length or less. Make sure the USB cable goes directly from the printer to the PC with no intervening devices in between such as a USB hub.
Step three: Check the paper or specialty printing material
  • Make sure the media is not damaged, scratched, or curled. Always store printing materials in a sealed plastic bag, especially in a humid environment, to help protect the material from damage or curl.
  • HP inks and media are designed to deliver optimum results. Other media may not perform as well.
Step four: Increase the print quality mode
If reprinting did not help and the paper or specialty printing material is not damaged, check the print quality mode:
  1. Open the Printer Properties dialog box.
  2. On the File menu in your software program, click Print .
  3. Make sure your printer is selected.
  4. Click the button that opens the Properties dialog box. Depending on your software program, this button might be called Properties , Options , Printer Setup , or Printer .
  5. Click the Features tab.
  6. In the Print Quality drop down list, choose a higher print quality (for instance, if the print quality is Fast Draft or Normal , switch to Best or Maximum DPI ).
Step five: Clean the printheads using the printer control panel
If you still see streaks or lines in your printouts, clean the printheads using the printer control panel.
NOTE:Always allow the printhead cleaning routine to complete. If the printer loses power in the middle of a cleaning, make sure to repeat the cleaning and allow the printer to complete it.
  1. Press Menu on the printer control panel. Figure 3: Menu button on the printer control panel
how can I get rid of lines on photos - 75b681b9-ee6e-426d-8740-fa0d2e25518c.gif
  1. Using the arrow keys to move through the menu options, find and select Clean printheads , and then press OK .
  2. Following the directions on the printer screen, load paper so the printer can print a test page after cleaning the printheads. Use plain paper to conserve photo paper.
  3. Press OK to begin cleaning the printheads. A Print Quality Diagnostic page prints at the end of the cleaning. Figure 4: Print Quality Diagnostic page
  1. If there are white lines across any of the color blocks on the Print Quality Diagnostic page, press Cancel to repeat the cleaning.
  2. Cleaning may be repeated a number of times. The number of cleanings (and therefore the length of the procedure and the amount of ink and paper used) will vary depending on the severity of the problem. A Print Quality Diagnostic page is printed after each cleaning. Look for white lines through the blocks after each cleaning, and if the print quality seems to be getting better (fewer white lines), continue to repeat the cleaning. Eventually, a Recommend Six-Minute Cleaningmessage will appear on the printer display. If the print quality has been improving, press OK to perform six-minute cleaning.
    • As soon as the white lines no longer appear in the color blocks, the problem should be solved. Print a normal print job to confirm that the print quality is acceptable.
    • If the print quality is still bad after the six-minute cleaning, or does not improve with repeated cleaning, or is not acceptable even though there are no white lines through the color blocks, go on to the next step.
      Step six: Align and calibrate the printheads
      If you still see streaks or lines in your printouts, align and calibrate the printheads.
      1. Align the printheads:
        1. Load plain, white, unused paper in the main tray.
        2. Press Menu on the printer control panel. Figure 5: Menu button on the printer control panel
    1. Select Calibrate Printer , and then press OK .
    2. Select Align Printheads , and then press OK .
  1. Reset the closed loop calibration:
    2. Select Calibrate printer , and then press OK .
    3. Select Reset closed loop calibration , and then press OK .
    4. The printer LCD will display Ready .
  2. Color calibrate the printer using closed loop calibration.
    1. Load HP Advanced Glossy Photo Paper in the main tray.
NOTE:Only HP Advanced Glossy Photo Paper should be used for this process. If plain paper is detected by the printer, the calibration procedure may fail or print quality may be affected.
    2. Select Calibrate Printer, and then press OK.
    3. Select Closed Loop Calibration, and then press OK.
Step seven: Clean the printheads manually
If you still see streaks or lines in your printouts, clean the printheads manually:
  1. Gather the following items to clean the nozzles on the printheads:
    • Distilled water (tap water might contain contaminants that could damage the printheads)
    • Cotton swabs or other soft, lint-free material that will not stick to the printhead
    • Sheets of paper or paper towels to rest the printheads on
  2. Open the top door of the printer.
  3. Press and hold OK until the printhead assembly moves to the left side of the printer and stops.
  4. Raise the printhead assembly cover.
  5. Remove a printhead and place it on a piece of paper with the ink nozzle plate facing up.
    Figure 6: Removing a printhead
    how can I get rid of lines on photos - 30d99a41-4c4a-4257-8d32-275b6505dcad.gif://i.fixya.net/uploads/images/30d99a41-4c4a-4257-8d32-275b6505dcad.gif" alt="30d99a41-4c4a-4257-8d32-275b6505dcad.gif" class="h_mi" />
    NOTE:Do not touch the ink nozzle plate with your fingers. Touching the ink nozzle plate will result in clogs, ink failure, and bad electrical connections.
    NOTE:Do not leave the printhead outside the printer for more than 30 minutes. Ink nozzles exposed to the air longer than this might dry out and cause printing problems.
    1. Lightly moisten a cotton swab with distilled water and squeeze any excess water from the swab by pressing it against a clean plastic or tile surface. Do not use your fingers to squeeze the excess water from the swab, because the oil from your fingers could contaminate the swab.
    2. Gently wipe the nozzles on the printhead with the cotton swab. Fhow can I get rid of lines on photos - 6ad22fec-fdff-448d-8e80-3acdfb93d75c.gif
    1. Wipe until no ink residue or dust appears on a clean swab.
    2. Insert the printhead in the printer.
    3. Repeat thehow can I get rid of lines on photos - note.pngbove for each printhead. When all the printheads have been cleaned and reinstalled, close the top door of the printer.
      NOTE:If a message appears on the printer screen directing you to replace a printhead, click the Contact HP link on this page to contact HP support.
    Step eight: Replace the printhead
    If you still see streaks or lines in your printouts after performing all the steps above, one or more printheads may need to be replaced. If your printheads are still under warranty, click Contact HPon this page to arrange to replace the printheads.
    I Hope Your HP Printer Problem Is Solved By Now,In case You still Having HP Printer Problem,Then I suggest You Visit Below URL Link:
    http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00725354
    Or
    If You still Need assistants Then Follow Us On:
    HP Printer Support
Posted on Feb 13, 2014
I have an olympus sz 14 and have a swirly white lines when I try to take a photo
Please check the shooting mode.
Restore Default might help
Sep 08, 2014 | Olympus Cameras
This evening I bought a new HP Photosmart C4780 printer. I am trying to print photos now and the photos are being printed with small vertical lines across the whole photo. How do I get rid of them?
> I bought a new printer
Take it back, and get one that does work correctly.
> VERTICAL lines ACROSS the whole photo
Hold the paper in "portrait" mode, not "landscape" mode.
Are the lines HORIZONTALLY-ACROSS the paper,
or VERTICALLY-DOWN the paper?
If those lines are WHITE and HORIZONTAL,
then some of the many ink-jets inside the print-head are *CLOGGED*.
Run a "print-head-cleaning-cycle" to try to unclog it.
Or, exercise the WARRANTY, and get it replaced.
Sep 24, 2010 | HP Office Equipment & Supplies
Nikon Coolpix s210 lines in photos
it cant be fixed BUT it doesnt mess up your pics wen u print them off
Jul 14, 2010 | Nikon Coolpix S210 Digital Camera
Lines throughtout photos
It's probably dust built up on the rollers, I suggest trying to print a cleaning page. Refer to your manual for instructions.
Apr 30, 2009 | Office Equipment & Supplies
There are lines in my photos after printing them out
two things can cause this, one you could be running out of ink,two the picture is too large for its low resolution print out.try just printing in 4by6 or 3by5 format and see what you get.good luck. i hope i helped.
Apr 14, 2009 | Epson Stylus Photo R260 InkJet Printer
Lines appear across the photo when you print it
Try running the head cleaner function a couple of times.
That should solve your problem.
Feb 24, 2009 | Epson Stylus 1400 InkJet Photo Printer
Horizontal lines through my printed photos
Are you sure your ink is not on the verge of finishing? Try changing the colour ink and print again. Sometimes I take the cartridge out, shake the ink down just in the same flashing motion as I do my pen, then replace it. You may try that.
Jan 20, 2009 | Canon PIXMA MP970 InkJet Printer
Lines on the photos
all you have to do is tap the camera onto your palm 3 or more times..not too light, but not too hard
this should get rid of the lines
Sep 09, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
HP PSC 1209 All-in-One InkJet Printer Logo
76 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
