Question about Kenmore Washing Machines
Kenmore 2801 does not spin at end of wash cycle
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
  • 21 Answers
SOURCE: wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Posted on Dec 29, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 3 Answers
SOURCE: Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Posted on Mar 04, 2009
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore elite washer sm 9711034, washer will not go through spin cycle at end of wash cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 19, 2011 | Kenmore Washing Machines
Kenmore 110 washer fills and does the wash cycle but wont drain or spin. Totally shuts down after wash cycle. What do I need to replace
sounds as though the lid switch has gone bad, either that or the motor has lost the reverse winding on it.. most likely lid switch tho.
the lid switch is only "seen" by some older kenmore "110" series at the end of the wash cycle, or end of the rinse cycle. it purpose is to keep the unit from spinning if the lid is opened so no one looses an arm, etc.
generally the console on those machines hinges over backward so you can remove the cabinet top and 3 sides as a unit together..
the lid switch is under the machine top and isn't easily accessible without removing the cabinet.
May 20, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
At end of wash cycle, water won't pump out of washing machine
You need to try to put your clothes in the scale to messure the right amount of clothing you will be washing at the time.
Oct 28, 2009 | Kenmore Washing Machines
Wet clothes at end of spin cycle
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
27 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
