It does not switch on. I have checked the switch it seems fine.....changed the fuse even that did not resolve the problem....taken the filter out cleaned it and put it back ..again no joy....what else can there be...if it is motor then should I have not smelt something burning....not sure what else to check.
SOURCE: Dyson DC14 Loud shrill whistle noise
Check and cleaning Brushbar Assy and Violet Cyclone Assy or replaced Brushbar Assy and Clutch Assy
SOURCE: dyson dc14 died, no power after burning smrll
It sounds like the motor has overheated and has now been irrepairable damaged.
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Testimonial: "thanks so much for taking the time to reply...sounds like we need a replacement!!!...will get the dyson ball this time..hope it's good! thanks again!"
SOURCE: Dyson DC 25 Ball - no power to motor
Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
SOURCE: We have a dyson dc14 and the beater bar stopped
Hi its Darran at Dyson.
Check that the brush control dial is in the centre position when the machine is locked upright. When you release the head and pull the handle back this dial should mopve forward to the on position. Once here, the brush bar should turn.
If this doesnt resolve the problem, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
SOURCE: No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
