Question about Chevy S-10 Blazer 90-97 BT-1858
1997 blazer, four wheel drive does not engage but push button lights work
    Genius:
  • Axxess Master
  • 1,028 Answers
Check the incoder motor on the transfer case, make sure it clicks, maybe its not getting power.
Posted on Feb 15, 2014
I have a 1996 chevy blazer and dont know how to disengage from four wheel drive to two wheel drive?
As I recall the 96 blazer had electronic shifting for 2wd to 4wd. There should be a small panel on the drivers dash buttons for 2wd, 4wd lo and 4wd hi.
Simply press the desired button while stationary and if the system is functioning properly then it will shift and the light for the engaged type of drive will be lighted. Generally you would like to be in 2wd for this vehicle.
Mar 10, 2010 | 1996 Chevrolet Blazer
2000 blazer 4 wheel drive problem
It's most likely the "four wheel drive actuator" This is located on the front differential housing. It's cylindrical shaped and has a large hex (about
1-1/4") and two wires coming out of it. Usually they short out and blow the fuse but, I've also seen where they just quit working and sometimes they just get slow to work. The "actuator" has a heating element in it and it warms up, some sort gas, causing it to expand thus engaging the front wheels. In cold weather it may take a minute or so for it to engage, so put in four wheel drive and wait for a bit and see what happens.
Jan 05, 2010 | 2000 Chevrolet Blazer
I have a 1997 425 magnum 4x4 and am having 4 wheel drive trouble
I had the same trouble , I bypassed the switch in the gear shift box .
Oct 13, 2009 | Polaris ATV
PUSH BUTTON FOUR WHEEL DRIVE FORD RANGER NOT WORKING
the transfer case is sticking from non use, change the lube in the case ( Ford ATF) and drive it for awhile it should be ok then.
Apr 07, 2009 | 1988 Ford Ranger
1998 Chevy Blazer 4x4, $ wheel drive won't work (both 4hi & 4lo )
Reset the computer by disconnecting the battery. This should solve this. nutetral is for the four lo only to engage.
Mike
Jan 26, 2009 | 1997 Chevrolet Blazer
1994 chevy s10 blazer 4x4 push button type
small sylinoid on the top of the transfer case needs replaced. easy to do. it has three vacumelines going to it just trun out and replace like a bolt.
Dec 10, 2008 | 1994 Chevrolet S-10 Blazer
Transmissions
ok i think you have push button 4 wheel drive , so you might want to raise the car and check the wiring to the engage engine, if im wrong and you have a floor shifter check the linkage .
Nov 23, 2008 | 1997 Chevrolet Blazer
Chevy S-10 Blazer 90-97 BT-1858 Logo
61 people viewed this question
Top Axxess Vehicle Parts & Accessories Experts
Jonathan Buck
Jonathan Buck
Sam Akber
Sam Akber
ivan whisker
ivan whisker
Are you an Axxess Vehicle Part and Accessory Expert? Answer questions, earn points and help others
