Question about Proform 810 TR Treadmill
Treadmill turns on but wont run
All the lights come on . but the treadmill will not run. and you cant change the settings.
Console does not work it lights up but no buttons function
this just happen to mine this morning, can't find a fix. Help!
Mar 17, 2014 | Nordic Track Nordictrack Exp 1000...
Cant get it to run
If the timer goes when you press start there could be one of a few things wrong
  1. Wiring harness
  2. Drive motor
  3. Controller
Better to call for support 877-805-1030
Jan 02, 2014 | Proform XP 580 Trainer Treadmill
Err1 error message, york aspire treadmill
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Clean the sensor, test for open or faulty, tight the connector very well,adjust it, see the diagram attached.
God bless you
Jan 19, 2013 | Exercise & Fitness
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
C956 precor treadmill
Hi
not to sound funny but are you sure that you have this tread set in the units (mpg/kph) that you require. i have worked in loads of gyms and its a common problem that people think the belt is running to fast because its set in kph and that thinks its in miles eg 9mph = 14.5kph
you can check and change the units in the club setting menu.
hope this helps :)
Jan 07, 2010 | Precor C956i Treadmills with HR /...
Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Jun 08, 2009 | Exercise & Fitness
Proform 810 TR Treadmill Logo
32 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
