Question about Bose Panaray System Digital Controller Ii
Power is on and no signal is coming through the unit
I have a crate vtx 212 amp and the power comes on but none of the chanels comes on and no sound what so ever comes out. Nothing looks burnt or corroded idk what the problem is i need help lol
If sure that power is reaching and getting into unit, then confirm that a signal is also reaching unit. If both are positive, then your gear is FUBAR if signal is going into correct input.
Feb 13, 2017 | Crate Music
No right hand turn signal in front and rear there is power coming from the brake light switch it's got a new switch to turn signal switch I am stuck
indicator fuse ?
indicator flasher unit ?
http://www.howacarworks.com/accessories/testing-and-replacing-a-flasher-unit
Oct 05, 2015 | Cars & Trucks
I have an 02 kia sportage. my signal lights come on but dont blink outside. no lights for the signal lights come on on the dash at all. also, no hazard lights.
If the 15A HAZARD fuse in the passenger compartment fuse box is OK, power is getting to the hazard function of the flasher unit. Pressing the hzard switch should cause the hazard lights to flash. HOWEVER, there is an electronic time and warning indication system module connected to to the hazard switch lead and that may be affecting things. If the 10A TURN fuse is OK, power is applied to the turn switch (with the engine in START or RUN) and you state you can select a right or left turn. HOWEVER, the RED/WHT and RED/BLU outputs from the flasher unit connect directly to the front and rear turn lamps and the instrument cluster turn indicators so you are not getting any flasher output. Again, that electronic time & warning indication system module could be affecting things
Oct 26, 2012 | Cars & Trucks
My turn signals won't come on at all?
check the fuse if good then turn on the hazard lights if they work then you probably need a turn signal flasher which is a separate flasher unit then the hazard one.it usually looks like the hazard one so with the hazards on and locate it then you will know what the signal flasher looks like and you will also know not to change the wrong flasher unit.the signal flasher is often located at or near the under dash fuse panel or somewhere in the dash you don`t say what type of car your talking about.
Dec 12, 2011 | Cars & Trucks
No signal
How old is the unit? Have you reset the unit (Power reset)?
If the signal comes back on after doing a power reset, I would recommend changing the unit. It could be dying on you. Had a similar problem back with the same model, no matter what configuration I try internally.
You can try to upgrade your firmware, this might solve the problem also:
http://support.dlink.com/emulators/di524/tools_firmw.html
Jan 14, 2011 | D-Link AirPlus DI-524 Wireless Router
TH-P50HD3, Unit comes on with Lines in screen all
check possibly ysus board check out hcsd forum if you are a tech they will sigh you up great tool
Apr 27, 2010 | Televison & Video
Outside unit fan not working
The fan is told to come on by the control board that is being sent a signal by the thermostat. There are several things that will contribute to the fan not coming on:
1. The fan capacitor may be bad. When the signal is sent for the fan to come on, try to get it started with a spray from the water hose. If the fan gets up to speed, you have a bad capacitor.
2. The fan motor may be bad. You can remove and test the motor or replace.
3. The control board in the outside unit may be bad. Usually, this is difficult to troubleshoot without a meter and schematic. What you CAN do is to take all of the power off of the unit, including the power from the thermostat, and open the enclosure for the control board. Check for loose and corroded connections. You can clean terminals effectively with the eraser end of a pencil.
4. Check the power relay where thewiring comes into the unit. Make sure that the contacts are not burned, or welded together.
Best regards, --W/D--
Aug 11, 2009 | Bryant Heating & Cooling
Hitachi PDP 55HDT79 got no picture
that power supply is a switch mode power supply,which means it looks for an input signal to turn on.
that signal comes from the main pc board.
if there is excessive current draw,it will shut down.
check the input,and the screen circuit it is driving
May 13, 2009 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
Bose Panaray System Digital Controller Ii Logo
53 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
