Question about Acer Aspire R7
How do i close a dialog box so i can open microsoft word?
I am trying to open up Microsoft word, but every time I try it says "Word can not open because a dialog box is open. Please close the dialog box and try again." How do I close the dialog box?
SOURCE: Laptop wont start properly
yes i tried using safe mode but its the same prob over again
Posted on Dec 27, 2007
  • 54 Answers
SOURCE: product key for microsoft 2007
Is it a Legal Copy of Microsoft Office ,what you using.If it so then you can get this Cd-Key with the cover of media what you have for office.If it is preinstalled from Company and if it is a licensed then you can get the key after online registration.
If it is Trial period like 60 days / 90days version then you have to purchased the licensed Office
Posted on Mar 28, 2009
jcoady
  • 79 Answers
SOURCE: I am completely unable to
Note: This solution is a complete steal from another MS Office support forum, but I'll take credit for it anyway:
With all Office apps closed Use Start=>Search and locate the file opa12.dat and recycle it, then restart the PC, start one of the
Office 2007 trial edition apps and see if you can activate it.
Note: You may need to use an exhaustive search, including hidden files, etc.
If you can't locate the file thru the use of Start=>Search:
1. Click Start, click Run, type %AllUsersprofile%\Application
Data\Microsoft\Office\Data, and then click OK.
2. Locate the Opa12.dat file in the Data folder.
3. Right-click the Opa12.dat file, and then click Delete.
Important Do not delete the Opa12.bak file.
4. Close the folder.
5. Start a 2007 Office program to start the 2007 Office Activation Wizard.
Note When you uninstall the 2007 Office product, the license file is not removed. Additionally, the license file is not overwritten when you reinstall the 2007 Office product. By deleting the Opa12.dat file, you force the license file to be recreated.
(info found in the MS Knowledgebase)
After that start Word or other Office app and the activation wizard is prompted and you should be able to activate.
(Found here: http://forums.techarena.in/ms-office-support/671246.htm)
Posted on May 27, 2009
gherna1
  • 190 Answers
SOURCE: dialog box is too big for screen.
Try changing the scanning resolution before running the scanner. There's usually a utility program with every scanner you purchase that allows you to do that.
Unless you're a professional photographer who needs to blow up a standard size picture to a poster or bill board size, you may only need 100-200 dpi resolution.
This will create smaller files that may overflow your screen size, but are manageable.
Posted on Aug 21, 2009
carsandcomps
  • 722 Answers
SOURCE: My PC doesn't load
Restart computer. Watch closely at the bottom of the screen for an F command.
This F command will allow to enter setup.
When computer is loading, start pressing F12 repeatedly until setup is opened.
When setup opens, you'll see a file menu that runs across the top of the screen. It will start from the left and move to the right - press F9. When prompted, select "restore default settings". Move to each file menu and press F9 and set "default settings".
When you come to the Exit menu, do the same thing, then select the Exit Menu, and choose the "Exit Saving Settings" option.
Once it exits, it will automatically restart and begin the loading process into Windows (or your operating system).
If the OS does not load, you will need to re-enter setup: under the file menu, search for an option that will allow you to enable a second F command which should be F5 or F10. Once this is done, go to exit, and select "exit saving settins".
The computer will begin loading, but you will want to restart the computer - watch again at the bottom of the screen for the new F command - remember what it is when you are in setup, and begin pressing it as before with the F12 command - the F5 (F10) will bring you to an option menu for starting the computer - select the "start in safe mode" option.
If the computer does not load in safe mode, you will need to format the hard drive and re-install the Operating System.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Posted on Jul 23, 2010
How to close dialog box that will not close
There is probably another dialog open that is preventing you from closing the one visible on your screen. try pressing [ALT]+[TAB] to see if you can make it visible.
The other option is to open Task Manager and locate the application/process that's generating the dialog and end it.
Jul 02, 2014 | Microsoft Office Word 2003 for PC
Unable to open a saved doc in word because of open dialog box.
may be it is asking for the serial no. kindly install the serial no and use the application.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Jul 19, 2010 | Microsoft Office Word 2003 for PC
How do i close the box?
If you see a red X in the upper right corner, click it. The dialog box will close. If you do not see one, ALT-F4 (hold ALT and tap F4) will close any open dialog box without a mouse.
May 06, 2010 | Microsoft Office Word 2003 for PC
Cannot open the microsoft word because trial locked. thanks!
Try the following steps:
  1. Start Word.
  2. Click the Microsoft Office Button.
  3. Click program name Options.
  4. In the navigation pane, click Resources.
  5. Click Activate next to activate Microsoft Office
If this doesn't work, Microsoft has more help here.
Jul 13, 2009 | Microsoft Office Professional 2007 Full...
I am trying to open a file, and I keep getting a message that, I need to close my dialog box first. What is a dialog box? and how do I get to it to close it? Please help?Microsoft word
What type of file is it ? For some reason the machine is not happy with the opening of that file and is asking you a question which it needs an answer to. When it asks the question press Control Alt Delete to open Task Manager you will be given the option to shut it down.
Jun 16, 2009 | Microsoft Computers & Internet
Troubleshooting MS Word 2003 XP
Hold down your ALT key, and touch the TAB key.
You'll see a list of "open" windows.
Touch the TAB key again, and the "outline" rectangle around one item in the list will move to the next item.
Release the ALT key to "focus" on the window.
If it is a "dialog" window (with 'yes' or 'no' or 'cancel' buttons),
close the window.
Repeat the hold-down-the-ALT-and-touch-TAB until you have closed the "dialog" window that is "blocking" Word.
May 21, 2009 | Microsoft Office Word 2003 for PC
How to close dialog box to open microsoft word office
im having the same problem!!!! im trying to finish my paper for my geograhy class. but theres a pop up that wont let me for to my work tht i've already done...its telling me to vlivk ok, and then close open dialoge boxes to continue! WHAT DO I DO?????
Jan 05, 2009 | Microsoft Office Word 2003 for PC
MS Office Word
how can i install tha microsoft word to my computer.
Oct 21, 2008 | Microsoft Office Professional 2007 Full...
Acer Aspire R7 Logo
670 people viewed this question
Top Acer Sport & Outdoor - Others Experts
Are you an Acer Sport and Outdoor - Other Expert? Answer questions, earn points and help others
