Question about NorStar Meridian M7310 Phone
Display comes up with symbols and numbers
Display keeps changing, mostly $ signs
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
Where is the euro sign?
if you mean dollar hold shift and number 4
Feb 17, 2015 | Samsung Chromebook Series 3 XE303C12
Can't sign into my new Dell Inspiron 15 with windows 8 because it keeps typing caps
open hotmail in any browser then change your password in capital like"ASDREWSDF" then save it and then again log in through it from windows live account
Feb 04, 2013 | Dell Inspiron Computers & Internet
How can I write a pound sign by using a dell keyboard
The easiest way is to hold down the Alt key and type "156", then release the Alt key. You will see a British pound (£) sign appear. However, sometimes "pound" means the number sign (#), but that's mostly used in voicemail prompts.
If you use the first pound symbol a lot, you can either keep it on the clipboard, or consider remapping a key you never use (like the tilde, or ~) to type that character (see http://www.annoyances.org/exec/show/article02-022).
Hope this helps!
Apr 08, 2011 | Dell 0Y3740 Keyboard
I cannot get the qwerty keyboard on my HTC desire HD to display a pound steling sign, it only seems to have a dollar sign
The Pound Sterling sign is available. Please follow these steps:
  1. On the keyboard hit the ?123 keyboard to bring out the numbers and symbols layout.
  2. Now, hit ALT to show the alternate symbols layout. The Pound Sterling symbol is available in place of # in this layout.
Hope this helps. If so, please consider rating this solution.
-regards,
M
Mar 12, 2011 | HTC Touch HD Smartphone
There is a symbol above my f4 button on my latitude e4300 laptop and i would like to know what this means?
Not knowing what the symbol looks like, it is hard to say.
You have to press and hold the "Fn' button to enable the function
In most cases it is to change resolution and/or display options, if it is a sign with two rectangles / one rectangle.
Used to change resolution when connecting a projector or other external display
Sep 13, 2010 | Dell 0Y3740 Keyboard
The left side of our ti-84 will not display after
Would it help if I told you that all the precision you are apparently looking for has no meaning?. In any number resulting from a scientific calculation only a limited number of digits are truly significant.
If you are entering characters (numbers, symbols, letters, etc.) the calculator keeps accepting them until its memory is full. At this point the cursor changes and go from a solid rectangle to a checkerboard-like rectangle, and you cannot enter anything anymore.
But if you are calculating some meaningful expression, the calculator displays the result according to the display mode you selected: Normal, Scientific, or Engineering). However, even in normal mode, if a number is too small, or too large, the calculator displays it in scientific format.
Scientific format
This format is as follows
  1. A minus sign if result is negative. If positive (+) is omitted.
  2. One digit
  3. Decimal mark (.) or (,) according to configuration
  4. A certain number of decimal digits (maximum 9)
  5. The E to symbolize ( times 10 to the power of)
  6. A minus sign (if exponent is negative), nothing if positive
  7. A maximum of 2 digits for the exponent of the power of 10. The maximum exponent you can have is 99
Let us count the number of possible characters in a display
-1.123456789E-12. That is 16 character slots.
Try playing with the number 987654321123456. All you will see is 9876543211E12. The 23456 sequence disappears, and all that "precision" is lost. Why, may I ask, should you worry that your calculator is not displaying more that 13 characters on the left.
This is what I understood from your one-liner of a question. And because it is a rather cryptic one-liner, I may have gotten the whole problem wrong. If that be the case, do not just shoot down the answer, post a comment to the solution describing what you are trying to do. If it is a bona fide worthwhile concern, I will do my best to help you with it. If on the other hand, it is jus plain idle doodling I will leave it at that.
Dec 19, 2009 | Texas Instruments TI-84 Plus Calculator
Dell Wireless keyboard
You have your keyboard input in a different language to the keyboard layout. Change it through control panel and regional/language options.
Jun 09, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Ten zeros when you start
The Fix sign on the top of the screen (smaller size) are indicators that calculator is using the FIXed format: All numbers are displayed with a fixed number of decimal digits (in you case it may have been set to 9 decimal digits). You can change that in the setup.
The Grad symbol means that the angle unit is set to grad. This too can be changed to degrees or radians in the set up.
A sure way to achieve mastery of calculator use is to learn how to configure it to fit the types of calculations to be performed.
Hope it helps.
Nov 24, 2008 | Sharp EL-531VB Calculator
NorStar Meridian M7310 Phone Logo
16 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
