Question about Samsung Microwave Ovens
My samsung bce1197 keeps switching itself on and then freezes
My samsung SMH8165W the fan keeps going but nothing else. Can I fix this
If it starts running as soon as its plugged in you may have a bad or out of align door switch. Humming noise could be the mag if its not heating. Replace mag and diode/rectifier
Nov 19, 2014 | Samsung Microwave Ovens
Oven turns itself on
THE DOOR HAS A SAFETY SWITCH THAT SHUTS THE UNIT OFF WHEN THE DOOR IS OPENED KEEPING YOU FROM GETTING "ZAPPED WITH RADIATION" ACTUALLY ITS JUST RADIO WAVES, ANYWAY THE JIGGLING OF THE HANDLE TO START IT IS WHATS HAPPENING THERE. IT COMING ON IS JUST A SHORT IN THE SWITCH THAT MAY BE FROM AN ALREADY SET TIME, OR ITS JUST MAKING CONTACT WHERE ITS NOT SUPPOSED TO. ANYWAY YOU NEED A NEW DOOR SWITCH.
Dec 03, 2007 | Samsung SMH7174BC Microwave Oven
How to fix SE in the control panel of microwave
Remove power and clean the inside while checking if there are food particles on the inside or in the Wave-guides- the portion where the Magnetron is fitted. Also remove the main cover and clean the areas of the Magnetron , check for loose joints,Finally check if the main capacitor is faulty. Other wise you will need a check on the main board, and also the Magnetron for leakage.
Sep 03, 2014 | Samsung SMH9187 Microwave Oven
Error code se micro wave samsung?
Error code indicates a shorted membrane keypad switch. Manufacturer suggests you unplug the oven for an extended period of time to see if it will clear the code itself. If not, you may actually have a bad switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jul 10, 2014 | Samsung SMH7178STD Microwave Oven
Emerson mwg9115sl
You may have a shorting door switch or one of the door switches mounts may be loose, misaligned, or broken.
See my help file on door switches here
Jan 19, 2014 | Microwave Ovens
I have a Frigidaire freezer , M# GLFU1767FW4 S# WB70936901. The computer keeps on beeping, even when the door is closed, the temperature is fine. I already changed the computer and the door...
Hi, the door switch might have had liquid poured on it freezing it, or the switch itself is bad.
Unplug your refrigerator from the ac outlet, and 0pen the door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door.
Nov 24, 2010 | Microwave Ovens
Ice forming in my frost free whirlpool fridge
There are a few reasons why this is happening. One and usually the most common is the the heater for the coils in the freezer is not working.These heaters are controled by a timer that lets it run for a while and then shut off, this keeps the coils from freezing up and collecting moisture. 9 out of 10 times it is the timer mechanism that goes bad and it is a reletivly cheap and easy repair. Also make sure the gasket on the freezer is in good shape and not allowing outside moisture in where it can condense and freeze along the wall of your freezer, keeping the door open too long will also create this effect, but if the heater is working correctly it usually will take care of itself. You may also want to make sure there is good air flow from the unit itself and blowing good cold air around in the freezer.
Nov 16, 2010 | Microwave Ovens
Keeps blowing breaker
Did you call Samsung's Service Division at 800-932-3837?
They may be able to give you a better number to call.
If you don't have them, you can download Samsung over the range microwave installation instructions here.
Please let us know what you find out.
Oct 22, 2008 | Emerson MW8987B/W Microwave Oven
Samsung BCE1197 oven stopped working after making a noise which I think may have been the fan, maybe something caught in the fans blade or a mechanical problem, anyway I changed the fuse in the plug, still...
Since this is a UK Model, I'd suggest you contact Samsung's to find service info here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 16, 2008 | Samsung Microwave Ovens
Microwave Ovens Logo
20 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
