Question about Garmin StreetPilot 2620 GPS Receiver
As I type this at 8:11 AM on Jan 13, my 2620 says it's 5:45 AM on Jan 27, about 2 weeks in the future. How can this be reset?
I've done resets, run the diagnostic routine, everything seems normal. But of course it can't reconcile satellites with wrong date. Time for the dumpster?
  • Garmin Master
  • 8,016 Answers
Probably not. Time to read the manual to learn how to set the time. You may let it synchronize with the GPS signals, or set the Time manually.
Posted on Feb 14, 2014
SOURCE: System date and time are wrong
go to the tesk bar and double click on date icon and set correct time
Posted on Feb 03, 2008
SOURCE: Garmin GPSMAP 60CS displays wrong date
mou exoun dvsei ena gps to opoio mesa einai ola sbismena.
prospathw na tou perasw ena ellhniko xarth alla den mporw...
xreiazomai help.......
Posted on Feb 03, 2009
ZJLimited
  • 17970 Answers
SOURCE: was working OK until a
Just in case you are new to Sat-navs; are you trying for satellites out of doors and away from tall buildings? Turn it off, then on again as says this procedure:
1. Go outdoors to an open area with a clear view of the sky. Stay away from tall buildings and trees.
2. Flip up the Garmin GPS antenna (on the back of the device) so that it's parallel to the ground.
3. Press and hold the "Power" button on top of your Garmin GPS device to turn the unit on. If your unit is trying to acquire satellite signal for the first time, it may take 3 to 5 minutes for the connection
NOTE: Make sure you have a clear view of thre sky (not indoors or outside but near a large building.
Several factors affect the speed at which your Garmin GPS device acquires satellite. The more frequently you use your GPS, the less time it takes for it to gather the data it needs to acquire satellite signals. Using your GPS indoors, traveling more than 500 miles without the GPS tracking your travel, and the first GPS use after a software update are all factors that can increase the time the unit needs to locate satellite signals.
Another thing people can miss/forget, is the time/date set correctly? Also, if it hasn't been used for a while it can "forget" where they are, and so takes longer to re-acquire them. For this, I suggtes check in the Nuvi 310 OwnersManual (pdf format).
Other owners experimented the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching...
The unit appeared to have "stuck" in this acquiring mode. The following worked for they:
1. open the GPS antenna
2. press the bottom left screen while holding the power button to turn the unit on
3. enter maintenace mode
4. select diagnostics
5. clear error report, do NOT clear any user data
6. restart unit the usual way
In oter cases (GPS 350) was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Hope this helps.
Posted on Jan 19, 2011
  • 81 Answers
SOURCE: My Edge 305s GPS is not working. Everything else
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles
Hard reset is not very easy, so follow carefully instructions above.
Now simple advice, did you check in your parameters that the GPS transceiver is turned on ?
There is a mode with GPS off, don't ask why ...
Refer to your manual to find the menu.
Posted on Feb 23, 2011
  • 1514 Answers
SOURCE: cant locate satellites on my
Try updating the operating system software.
  • Download and install, to your computer, the latest version of WEBUPDATER from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
  • Connect your satnav to your computer and run the webupdater program.
  • It will find any updates to the satnav operating system. Select all and install them.
  • When the updates are installed webupdater will find optional updates. You don't need to install these unless you want to.
When they are downloaded safely disconnect your satnav and re-start it. This may solve your problem.
Posted on Aug 05, 2011
My ematic 4gb EM63 7" is stuck in trying to complete turn on process, cannot get p.ast the logo and blinking lights. I simply cannot turn it on. I've only been using it since Jan 2014. Been trying to
So I guess nothing else to do but to get it to boot from a SD card with Android 4.1 on the SD Card, It appears your's is corrupted, there is a number of sites where you can download along with directions to make an Android boot card. Hope this gets you up and running.
Apr 22, 2014 | Ematic 4GB EM63 7" HD Dual-Core...
DNS server or whatever...
Check your firewall is turned on or not.
Hold down the Windows key and press R. (This will open the Run dialogue.)
  1. Type "cmd" and press Enter. (This will open a command prompt.)
  2. Type "ipconfig /flushdns" and press Enter.
  3. Type "ipconfig /registerdns" and press Enter
  4. Type "ipconfig /release" and press Enter.
  5. Type "ipconfig /renew" and press Enter.
  6. Type "netsh winsock reset" and press Enter.
  7. Reboot the computer.
May 08, 2013 | Fujitsu Siemens Computers & Internet
Model 50HM66 has no sound
Hello
You have done a hard reset to this tV as you have unplugged it from the power socket. This is the procedure you should do, when your TV display this type of probelm in future.
Mar 02, 2012 | Toshiba Televison & Video
Forgot my login password to Windows 7
What if you forgot windows 7 password by accident? How to crack windows 7 password by yourself? Try this
wonderful SmartKey Windows Password Recovery as soon as possible. The same as Windows 8 password recovery tips.
Step 1: Download and install, run the program on a unlocked computer.
Step 2: Burn a bootable CD/DVD/USB Flash Drive with the program.
Step 3: Reset Windows password by the burned CD/DVD/USB Flash Drive.
Now it has promotion until Jan 15th,2013
http://www.recoverlostpassword.com/promotion/christmas.html
Sep 08, 2011 | Computers & Internet
I bought a G1 off of eBay. I've had it maybe two weeks now. Whenever I send or receive a call, the person on the other line cannot hear me. I've tried restarting my phone, and that worked for a...
It can be microphone problem that is why the person you're trying to talked can't hear you,some can be done on software programming,other can be fix it by replacing the mic component. But i prefer to use your warranty card and get free charge of it,or if its no HTC service center near you,try to ask assistance to any mobile service shop preferably.DIY is not advisable for android phones,you might brake something and fixing this type of mobile is to complicated.
Jul 11, 2011 | HTC G1
I"ve created a password on
You can salvage your old user account by logging on as the "Administrator" user. Once you're logged in as the admin, you can reset your old user password. The Administrator user (by default) is similar to a "superuser" and has the highest access level to reset any user password.
If you don't know what your Administrator password is, you can reset that by rebooting into Safe Mode.
The best option here is to reset your account password. You can do this using either 1 of the 2 methods suggested by Microsoft Knowledge Base article #321305. In my opinion, the second method described on this page is most likely the easiest route:
Reboot Windows in Safe Mode.
Click Start, and then click Run.
In the Open box, type the following command, and then click OK: control userpasswords2
Click the user account that you forgot the password for, and then click Reset Password.
Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Side note: To access Safe Mode, Click Start -> Shutdown (or Turn Off), and choose 'Restart'. Once the computer restarts, press F8 repeatedly on the keyboard until a Boot Menu appear (this *must* be done before the Windows boot screen appears). Finally, choose to boot Windows in Safe Mode and press Enter on the keyboard.
Feb 15, 2011 | Computers & Internet
Hello , I have a D-Link DIR-635 Firmware Version: 2.33EU Hardware Version: B3 What is wrong that my internet connection fails now and then. Repeadetly , I get lag playing games. For one second all...
Try a new LAN cable between devices. Hard reboot bother router and modem.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Feb 09, 2011 | D-Link / RangeBooster N 650 / DIR-635 /...
Reset my system back in time
You can use the system restore tool to reset your system back to a date in past. Which operating system are you using? Because only Windows ME and later operating systems(windows 2000, Windows XP and Windows Vista) have this option.
Oct 20, 2008 | HP Computers & Internet
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
HP IPAQ 6315 Auto Hard Rest
my ipaq6315 shutsdown and resets,i keep losing data...help me pls
Dec 04, 2007 | HP iPAQ h6315/h6365 Pocket PC
Garmin StreetPilot 2620 GPS Receiver Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
