Question about Bernina Sewing Machines
I broke a needle and now my timing is out on my Bernina Artista 170. The hook is nearly a 1/4 inch in front of the needle when the needle is at its lowest point. Please tell me how to fix this. TIA
Ive had a longarm machine before so I am used to adjusting the hook position for timing. TIA
    Champion:
  • 276 Answers
Turn balance wheel slowly until needle has risen about 3/16" from lowest point. Move hook back until immediately behind needle and just above needle eye
Posted on Feb 17, 2014
RickE1
  • 202 Answers
SOURCE: Timing problem
You might have to look at loosening the set screws for the gear on the lower shaft that drives the hook driver gear . Loosen the screws, slide the gears apart, then adjust the hook so it is entering the scarf of the needle on the upstroke. Slide the gears togeather so they mesh again and it should be back in time. There are other factors though such as needle height adjustment which is done with the needle bar and hook and needle clearance (the distance between the needle and hook) which should be about .030. I'm a Bernina tech but many machines work the same principle. Good luck.
Posted on Aug 23, 2007
  • 106 Answers
SOURCE: bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Posted on Mar 30, 2008
SOURCE: Singer 758 adjustments for needle position and stich width
Found this below that may help confirm timing? As for the zig zag one thought is to check for end play in the upper shaft. At the left hand end of the shaft (under the top cover) there is an white plastic "bushing" with one slotted screw - this can be adjusted to take up the slack. It is possible that this bushing is split by the screw which may make it come out of adjustment. Check the other collars on this shaft are tight (hex) - by the belt and near the drive gear. P.S. double check the zig-zag cam is in the correct position (set to straight sew - centre position to install the cam - check instructions).
Timing
Turn the handwheel towards you until the needle is in the lowest position and observe two lines on the needle bar at the place where it comes out of the machine. You have to see these lines. When you find those, you have to tilt the machine on its back and you will see that on the right hand side there is a belt coming down onto a gear like piece on the timing shaft. Move your eyes to the left and the next thing that you will see is a large round gear on the feed shaft. Now that we have determined the difference between the feed shaft and the timing shaft, follow the feed shaft to the left and there will be a small metal piece there with two metal screws on it. Next to that to the left is a stationary metal peice that has a bump on it. You must see these two things to adjust your machine.
Now, to determine if your machine is out of time, turn the handwheel towards you (always turn it towards you) until the needle is in the lowest postion again. Observe the two lines on the needle bar, turn the handwheel toward you until the bottom line goes in the exact place where the top line was. Now look at the needle and hook. The hook should be directly behind the needle. If it is not, we go back to the bottom of the machine on the gear like metal piece that the belt rides on and loosen the two screws that are in the piece. Now if you will remember, this is on the timing shaft. When these two screws are loose, the hook will become moveable. Place the tip of the hook directly behind the needle without moving the needle bar (remember that the needle bars bottom line was placed where the top line was). When you have accomplished this, tighten the screws on the belt gear.
Now you have to determine whether the feed is in time. Again, place the needle in the lowest postion, rise the low line to where the top line was, and see if the line on the feed shaft is directly next to the bump on the stationary metal piece. If not, without moving the handwheel at all (because it must stay in this position to time it), loosen the two screws on the feed shaft piece and align the two lines together. Then tighten the two screws, make a few rotations with the handwheel, and again, put the needle in its lowest position and rise the bottom line to where the top line was. Inspect the two lines on the feed shaft and the hook behind the needle.
If these did not stay in adjustment, re-do the entire process, but be more careful not to move the handwheel when making the tightening adjustment. If you re-do this and it still does not stay in adjustment, you need to replace your timing belt,
Posted on Feb 24, 2009
SOURCE: Bernina 180 Artista sewing machine
you may have to replace the upper thread sensor
Posted on May 22, 2009
SOURCE: Pfaff 463 Industrial Sewing Machine needs Hook & Needle Re-Timing
ne sece konac
Posted on Dec 20, 2009
Is bernina artista 180 embroidery module compatible with bernina artista 170
Yes, The BERNINA Artista 180 and the BERNINA Artista 170 do in fact use the same Embroidery Module.
Sep 28, 2015 | Bernina Artista 170
My Bernina Artista 170 Sewing Machine Touch Screen is not responding, Touch Screen just not working, Touch Screen is maybe cracked, can it be replaced ?
Maybe Cracked screen???
If broken, the screen is just like cellphone screen, digitizer is also broken and screen won't respond to screen touches... Find a trained repair shop. EmbroideryServices
Apr 20, 2014 | Bernina Artista 170
Bottom stitching is loose
try adjusting the top thread tension one number or letter at a time
forwards till the stitch look normal
here is 2 link for a manual
http://www.sewingpartsonline.com/instruction-manual-bernina-artista-170-and-180.aspx
http://www.sewingpartsonline.com/manuals/Bernina/170,%20180%20(Artista).pdf
Aug 22, 2012 | Bernina Artista 180
My Bernina 170 needle bar will not go up and down
Just check that the bobbin winder is disengaged fully, this would cut out the needle bar action.
May 12, 2011 | Bernina Artista 170
Bernina Artista 640 - While embroidering, the sewing needle hit a pin and broke. Now that I have replaced the needle, the alignment is off. The needle point comes down onto the embroidery presser foot.
This will probably need to be handled by a professional. With this particular Bernina, you might be able to adjust the needle position so that it is slightly off center and will not hit the presser foot. That would be a temporary fix, however. If you want to be able to thoroughly enjoy your sewing time, you will be happier if you take it to a certified Bernina repair site and let them adjust the needle position.
Nov 11, 2010 | Bernina Sewing Machines
How do you oil a Bernina 170?
Remove needle, needleplate, presser foot and bobbin case. Now take a lint brush and clean under the feed dogs and hook area. take the bernina oiler(must be bernina oil only) now place a drop just below where the bobbin case clip on and one small drop under the feed dog area. replace items, sew out a test sample and away you go
Apr 25, 2010 | Bernina Artista 170
Do I need to oil the Bernina Artista 170? If so,
- yes \-every 3-5 hours of sewing or more if you are sewing very dirty fabrics (used canvas etc)
-remove the shuttle, clean and oil the "race" where the shuttle ocellates
-remove the light cover with the off set torues wrench included with your machine
oil the needle bar, take up lefver joints and the presserfoot bar. any thing more should be done by a qualified technicial who should remove back and front covers and remove lint and dirt and then oil all the bearings
drtension
Apr 23, 2010 | Bernina Artista 170
Apr 22, 2009 | Bernina Artista 180
Broke a needle
Best scenario is that the needle hit deflected and hit the hook that the bobbin snaps on to. When needles hit hooks they can leave a mark or burr that the thread will catch on when it comes around. Take out the hook and run your fingernail over the edge from the point back. If you find a burr get some crocus paper (very, very fine sanding paper and polish the burr off.
Next would be that your machine is knocked out of timing meaning a trech will have to reset it.
Dec 09, 2008 | Bernina Artista 180
My bernina sewing machine won't do zig zag stitch on one side. when i sew only one half of the sitch works.
Sounds like its skipping stitches. The very first thing to do is put in a new needle. A dull needle will cause this for sure.
After that it may take a tech to make some adjustments.
1) The hook is slightly out of time. On this type mechanism, there is
a slight difference in timing for the different needle positions.
2) The needle bar is slightly too high.
3) The hook and needle are too far apart, and then the skipping would
be more apt to show up on light weight fabrics.
Apr 16, 2008 | Bernina Artista 180
Sewing Machines Logo
89 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
