Question about Behringer C-3 Professional Microphone
Behringer c3 mcorphone not working -wires disconnected, red - 1, orage- 2 , black and brown diconected ?
Exist only one free pin and somting like hole on small metal
  • ankastrinity Apr 02, 2014
    Hi Mirjana Vladisavljev, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
2 Suggested Answers
SOURCE: Wire Colour coding for Behringer C1 Microphone
had same problem,checked with new mic,
red/black=pin1
orange=pin2
brown=pin3
Posted on Apr 09, 2013
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
It is likely that the brown goes to pin 1 (ground/shield phantom -) as well as the black.
Red is likely to go to pin 2 (across from 1)(signal +)
and the orange to pin 3 (signal -)
Apr 15, 2010 | Behringer C-1 Microphone
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
SHure SM57 mcorphone not working -wires disconnected
The wire coming from the switch if it has one will go to pin 2 as it is hot(+ve). Pin 3 is cold (-ve) and pin 1 is gound/shield which will make contact when the XLR connector is mounted back in the mike secured with the set screw. There should be a small hole in the side of the base of the mike that the set screw lines up with. Usind the correct size of flat bladed screw driver, back this screw out counter clockwise to secure the connector. If that is wrong, get back to me and i will hunt up my Shure wiring diagrams. If pin 2 and 3 are backwards the mike will be out of phase. Hope this helps.
Mar 30, 2009 | Shure SM57-LC Professional Microphone
Malfunctioning Garmin GTM 20 fused GPS power adapter
The two red wires are +VE Supply and both connect to pins 1 and 2
The two brown wires are Supply Ground and both connect to pins 8 and 9
Pins 3 through 7 are the traffic recievers digital interface:
Purple/violet connects to pin 3
Yellow connects to pin 4
Blue connects to pin 5
Black connects to pin 6
Green connects to pin 7
Dec 30, 2008 | Garmin GTM 12 FM TMC Traffic Receiver...
Cb mic wiring
I have a browning golden eagle mark II. It has a two pin mic plug. I would like to hook up a astatic power mic to it. Anyone have an answer?
Oct 07, 2008 | Magnum DeltaForce CB Radio
Im sittin here with the wiring harness for my 99 altima, and the wiring thing from the back of my pioneer deh p6700MP, i have no clue which ones to match with the other one?
Here's the manual for the Pioneer -->LINK<--.
This is the 2 options of install wiring on a 97 Altima, I'm not sure if it's exactly the same, I suggest that you don't trust these pinout if yours differ at all.
Radio Constant 12V+ Wire: Pink
Radio Switched 12V+ Wire: Blue
Radio Ground Wire: Chassis
Radio Illumination Wire: Red/Green
Radio Dimmer Wire: Red/Yellow
Antenna Trigger Wire: Green/White
Front Speaker Size: 4′ x 6′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Brown
Left Front Speaker Wire (-): Black/Red
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Black/Yellow
Rear Speaker Size: 6 1/2′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Orange
Left Rear Speaker Wire (-): Black/Pink
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Black/White
THERE IS AN ALTERNATE WIRING COLOR CODE
THERE IS NO CONTACT PIN OR EXISTING WIRE THAT IS GROUND !!!!! (some really strange things happen to aftermarket radios if you think the Red/yellow wire on pin 9 of the 10-pin connector is ground”!!!!!
Large 10-Pin Connector:
Constant Hot (Memory or Clock) =RED wire pin8
Switched (Ignition) Hor = Blue wire pin4
Left Front Speaker + = Blue/white pin1
Left Front Speaker - = Blue/yellow pin5
Right Front Speaker + = Brown pin2
Right Front Speaker - = Brown/white pin6
The Smaller (6-pin) connector is only for the rear Speaker:
Left Rear + = Red pin5
Left Rear - = Green pin4
Right Rear + = Blue pin2
Right Rear - = Pink pin6
Regards
Philip
Jul 21, 2008 | Car Audio & Video
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
Behringer C-3 Professional Microphone Logo
52 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
