When I boot I get an item on the initial screen which stays on all screens after boot. How can I remove it?
I get a notification about volume control in the middle of the screen which is on all screens as I use the computer. It used to come after the boot and refers to my sound program in Windows 8.1. I learned how to stop it, but tried a few more things to try to understand it but found it in the Foxconn screen that appears when the power is turned on. How can I restore a clean Foxconn initial screen? My motherboard disk is ITL-177.
  • Don Hamilton
    Don Hamilton Feb 19, 2014
    sorry to post such a non well thought out problem. My computer is not at fault it is in my monitor. I have a Philips monitor that is malfunctioning. This monitor has speakers which I have never user but the volume control has gone wild.
  • Don Hamilton
    Don Hamilton Jun 16, 2014
    I have found a solution to the problem. It is a hardware problem in the Phillips monitor.I gave the monitor to a friend who could implement the solution and bought a new one. Thanks for all your efforts. Don Hamilton
    Master:
  • 409 Answers
The volume buttons are probably stuck on. Try giving them some firm taps to see if they unstick, or go to Maplin and get some contact cleaner spray. Spray it on the buttons then press them repeatedly till they start to move. I had the same problem with one of my monitors.
Posted on Jun 16, 2014
Witchunter
  • 98 Answers
SOURCE: I have no sound from Intel DG31GL motherboard.
Have you tried these drivers? They are for Microsoft Windows XP.
Posted on Jan 16, 2009
colliewob
  • 781 Answers
SOURCE: My computer wont boot past Ai lifestyle screen(initial screen)
Boot from windows CD and after all drivers are loaded it will ask you what you want to do
"Install, repair etc" choose Install and then press the R key for repair and follow instructions from there
Posted on Feb 02, 2009
mshill172
  • 20 Answers
SOURCE: PC wont boot up unless i press reset button!!!
have you reflashed the BIOS
Posted on May 12, 2009
Geekman
  • 32281 Answers
SOURCE: Tecra M3 won't boot, hdd light comes on then off.
The hard disk can be installed in another computer, but it won't boot up and run unless the computer is the same make and model with the same devices as the previous computer.
If it is not then you need to do a fresh Windows install to get a working computer.
What you can do as an alternative is to install the hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Posted on Jul 31, 2009
  • 5 Answers
SOURCE: Computer shuts down while loading OS
I have the 6100 sm-m and was having same problem .. I went to ecs website and flashed to old bios then downloaded new bios ... when updating make sure you check the bootblock , dmi, and hole .. I also checked the update all ... seems to have fixed the loading of vista and has not shut off
Posted on Oct 15, 2009
After a power surge TV controls will not work have to hold the volume button to turn up the volume
Stephanie, TV will have to come apart to check for bad capacitors,etc. on the internal board.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Toshiba Televison & Video
Coby 8127 forgot pattern pass code S/N 043130000741
1. With the pad OFF depress the "-" key on the volume control and the power button at the same time and HOLD them down until the "Coby" splash screen comes up. 2. KEEP HOLDING THE "-" key down and RELEASE the power button until an android is displayed lying on its back. 3. RELEASE the "-" key and press the " " key on the volume control You should see the Android system recovery options on the screen. 4. After the menu appears, select the "wipe data/factory reset > Yes " menu item by pressing the "-" key until the cursor is on the line 5. Press power button to select 6. After it goes through resetting, using the volume key to navigate to the "reboot system now" menu item 7. Select the menu item by pressing the power button to select 8. Your mid9042 will now boot to an unprotected screen, BUT you will have lost any applications you downloaded. You will, however, save all pictures, etc. you have loaded. .
Mar 09, 2015 | Coby MID7036-4 - Kyros MID7036-4 7 4 GB...
How do I get rid of a silly graphic weather widget which overrides my weather photos after I accepted it?
Adding & Removing Widgets and Items from iOS Notification Center
Don't care to see Reminders or Stocks in your Notifications screen? You can add or remove anything:
  1. If you haven't already, unlock the iOS device swipe down to bring about Notifications panel
  2. Select the "Today" tab and choose "Edit" at the bottom of the list
    • Delete Widgets from Notifications: Tap the red (-) minus buttons alongside items to remove them from the Notification panel
    • Add Widgets to Notifications: Tap the green (+) plus button to add a widget to Notification Center
  3. Choose the "Done" button in the upper corner to set the changes in place
Any adjustments made to Notifications Center here will be visible when accessed from either the lock screen or elsewhere in iOS.
Dec 07, 2014 | Apple iPad 32 GB WiFi Tablet PC
How to restore to factory default
To perform an External Manual Reset of your handset to restore to factory settings, read instructions below and then perform.
  1. Power off the phone, press and hold volume down button, press power button.
  2. Screen will come up with "Fastboot", press Vol down key to cycle through choices until you get"Android Recovery", then press Vol up key
  3. Wait for the "triangle ! / Android" screen then go on to step 4
  4. Tap on bottom right corner of the screen (may take a few times). a menu will come up
  5. Tap on "wipe data/factory reset", and tap OK. Another Confirmation screen will come. Tap Yesand OK
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. Tap OK.
  7. Phone will reboot to initial setup MOTOBLUR screen.
Tip: Once you've reset your device, you can use your existing account to sync your contacts back to the phone.
(Steps on Gingerbread 2.3)
Remove and remount the battery and power up
If the phone still does not boot up to the MOTOBLUR screen, then perform the following Factory Reset instructions:
  1. Power off the phone, press and hold the Volume down button and Power buttonsimultaneously while powering up the unit.
  2. Screen will come up with "Fastboot" at the top of the screen, press Volume down key to cycle through choices until you get "Android Recovery", then press Volume up key to boot in this mode
  3. Wait for the "triangle ! / Android" screen then go on to step 4 android_recoveryscrn.png
  4. Press both Volume up and Volume down key simultaneously. A Recovery Menu will come up
  5. Tap on Volume down key until "wipe data/factory reset" is highlighted, and tap Power button. Another Confirmation screen will come. Tap on Volume down key until coming to Yes and tapPower button
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. TapPower button
To Perform a Factory Data Reset through settings menu:
  1. From the Home screen, press Menu
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset (Read notes for other options)
  5. Touch Reset Phone
  6. Touch Erase Everything
Oct 20, 2014 | Samsung Cell Phones
Locate amount of battery lfe
Hi! I am going to give you a solution assuming you have Windows 7. If this is the case, you should right-click on the bottom right corner of your desktop (right-click on the time/date...), where the icon for volume control is located... and select Properties. You should then see a screen where you can choose to turn on or off the icons/notifications for battery power.Another option is: Control Panel\All Control Panel Items\Notification Area Icons and will find it. Then turn on your battery power icon/notifications and you must be ok!
Mar 29, 2014 | ASUS Eee Computers & Internet
Hard reset motorola atrix dual core smartphone
  1. Power off the phone.
    NOTE: If unable to power off, remove and reinsert the battery.
  2. Press and hold the Volume Up + Volume Down and the Power button.
  3. The screen displays Boot Mode Selection Menu; press volume down key to cycle through choices until Android Recovery is viewed. Press the Volume Up key to boot in this mode.
  4. Wait for the triangle ! / Android screen to display, then proceed to step 5.
  5. Press both Volume up and Volume down key simultaneously. A recovery menu displays.
  6. Tap on Volume Down key until Wipe data/factory reset is highlighted, and tap the Power button.
  7. Another confirmation screen displays. Tap the Volume Down key until Yes displays, then tap the Power button.
  8. After user data is cleared, the reboot system now option is highlighted by default. Tap the Power button.
  9. The phone reboots to the initial setup screen.
Wireless
Nov 23, 2013 | Motorola Mobility Nice Atrix 2 4g Hd At&t...
My icon for the battery power monitor has dissapeared from my taskbar can you help me get it back please
Do you have Windows 7? If so, you can right-click on the bottom right corner of your desktop (try right-clicking the time/date), where the icons for volume control, wireless, battery, etc... should be and select Properties. You should then see a screen where you can turn on/off the icons/notifications for battery power (sometimes my volume control disappears and i have to do this.
Otherwise you can go here, Control Panel\All Control Panel Items\Notification Area Icons and you should find the same thing. Then just turn on your battery power icon/notifications.
Hope this helps.
May 22, 2011 | Acer Computers & Internet
I use to have a on screen volume control and now it doestnt show up.(i have a emachines computer)
The on-screen volume control icon on the Taskbar can be restored as follows....
1. right-click on a blank spot on the Taskbar
2. click on Properties at the bottom of the resulting pop-up window
3. in the Notification area of the Taskbar and Start Menu Properties window
4. click the Customize button beside the check-marked Hide inactive icons
5. in Customize Notifications, grab the slider bar on the right side and slide down
6. click on the row with the Name "Volume" and on its Behavior click v and set it to Always show
Feb 09, 2011 | Computers & Internet
Cannot access volume control
Re install Audio driver and restart your pc . now you can access the volume control. if you could tell us which mother board you are using , we could find out the drivers for audio
Feb 14, 2010 | Computers & Internet
The volume control on the desk-bar. Please help! Thank you,
Hi, 'right' click on the Taskbar, that's on the same level as the 'start menu button," select the Properties Icon, once the window open; click the Notification Area. "In the next window, there will be a "list" of items that can be viewed, and added to the "Quick Launch" list, when the computer boots-up! In the list is the Volume. Select the (check box), and the 'volume' will be present on the "Taskbar," you can do the same for other items; to be shown, or hidden. "Did this solution help? If so Helpful Ratings Feedback, is appreciated, thanks paul7of9"
Feb 14, 2010 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
David Payne
David Payne
