Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
Is there an automatic shut off or do I have to switch it off myself to stop the water flowing into the mug?
Hi, switch on the middle coffee button then the coffee streams into the mug, is the water flow supposed to stop streaming into the mug on its own, or do I have to turn off the switch to stop the water flow? For example: Is there an automatic shut off or do I have to switch it off myself to stop the water flowing into the mug? If I don't witch it off myself, the espresso / water overflows over the top of the mug.
5 Suggested Answers
SOURCE: Coffee spurting everywhere!
Unlike the other person offering a solution I have experienced this problem like you when making the first cup. I found that sending a blank shot of water through first does the trick before putting the coffee grounds on. Hope this helps.
Posted on Nov 01, 2008
  • 80 Answers
SOURCE: descaled machine, clean solenoid valve. now steam is coming
try replaced gasket in high pressure valve.
Posted on Aug 27, 2009
Testimonial: "this person is soooo helpful. It has been amazing to learn."
EsWorld
  • 1618 Answers
SOURCE: Hi, Our Gaggia machine will not disburse water
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Posted on Sep 17, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia classic espresso machine has stopped giving
Either the shower is blocked or the grind on the coffee is too fine.
Posted on Oct 21, 2009
It leaks water under the right side of the brew basket.
Leaks water when brewing ground coffee with a My K-Cup ...
https://www.ifixit.com/.../Leaks+water+when+brewing+ground+cof...
iFixitWhen I use the My K-Cup filter to add my own ground coffee and brew it, after it ... the machine starts leaking water at the same time, so typically the mug beneath the ... in the lid that has the needle opening in it (half sphere perforated basket below it). ... thewater could simply flow over the coffee, and go right down the sides.
Stop Leaks - www.My-Cap.com © 2015
www.my-cap.com/stop-leaks.html
Jan 01, 2016 | Coffee Makers & Espresso Machines
How do get water flow through the shower filter screen?
Hi Colin:
There is a product called CLR that we use regularly on our coffe machine, kettle, metal coffee travel mugs, thermos etc. Could be you're in an area where your source water has a lot of mineral content. Do you have similar problems with other appliances? If so, the problem lies with the water supply and not the coffee machine.
Hope this helps.
Mar 11, 2015 | Coffee Makers & Espresso Machines
Keurig B40 problems
Clogged ports see page 18 Manual for assistance.
Feb 28, 2012 | Keurig Elite B40 Coffee Maker
While trying to run through the set up steps, both the Small Mug and Large Mug buttons stay blue rather than flashing. After switching to a dedicated outlet, the Small Mug button finally started flashing,...
I just bought a Keurig Elite B40 Coffee Maker myself, had same issue, Caledl Keurig support, problem solved in seconds. Seems an import step was left out of instructions. The step before the blue lights flash, RAISE THE SILVER HANDLE ALL THE WAY UP AND THEN CLOSE. According to Keurig this tells the brewer that a human is present and aware the brewer is running, a safety feature. Be sure you have a cup in place.
Mar 08, 2011 | Keurig Elite B40 Coffee Maker
Does not brew coffee consistencty, water does not always flow from res tank...even if water flows down from tank the machine will make the heat noise show brew ready and when u push the button it either...
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 22, 2010 | Keurig B60 Coffee Maker
I am interested in purchasing this 6 cup brew station, but all pics I see use travel mugs. Can it be used with regular 10 -12 oz ceramic mugs for home use? How about 6 oz cups that match Corelle...
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
Feb 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
How do I descale a Krups Dolce Gusto machine?
_451.jpg_450.jpgSorry about picture quality, fixya only let you upload small file sizes
Aug 21, 2009 | Coffee Makers & Espresso Machines
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
